Need a little help with first horizontal mill
Results 1 to 10 of 10
    Mar 2020
    5
    Default Need a little help with first horizontal mill
    Hi All!
    My first post here. I've come across this forum a while back while searching for a horizontal mill and relevant information. This is a great site! I ended up getting a US Machine Tool Co mill and have been using it for a while now. Works great but I need some help. The previous owner didn't have the handles/wheels for it and I've been searching for some but can't find anything that will work. Could be that I'm not looking in the right place either. They need to mount to 3/8" square post. The handle in the middle would also need an extension so the table doesn't interfere with it's use. I've attached a picture as well.
    The other area I need some help with is a vibration. When I was putting on the large belt cover I loosened the bolts on the motor plate. I must have not got it back in the right spot since now there is a vibration when the mill is running. What is the best way to align the belt and try to eliminate the vibration? It's driving me nuts. I've moved the motor around on the plate a few times but nothing seems to work. I've also attached a picture of the motor.
    Thanks in advance.
    Brandon
    I'm not sure why the pictures are sideways either. They aren't that way on my computer.
    Feb 2011
    2,434
    1925
    1075
    What is keeping the belt tensioned? If it's just the weight of the motor, you need something to hold it in place as under even a little load a motor will want to crawl up the belt. Most machines with a hanging motor like that will have some kind of turn-buckle or screw to push the motor bracket down and hold tension.
    Does the vibration go away when you disconnect the V-belt? If not, it might also be that your pulley is out of balance or the motor has a bent shaft, if the vibration ends up being on the machine side of the belt, I'd start going through looking for bent or sticking parts. Could be a lot of things, so it helps to narrow down which moving parts or group of parts is the issue.
    Aug 2012
    California, Central Coast
    4,247
    2253
    1678
    How old is the belt? Old ones get stiff and if not used can have a vibration causing "flat spot" in it.
  4. Likes Rudd liked this post
    Mar 2020
    5
    Quote Originally Posted by M.B. Naegle View Post
    I should have mentioned that I didn't notice the vibration when I first used it. It was only after I tried to install the belt cover. It was hitting the pulley ever so slightly so I tried to adjust it to fit. Now I have a vibration. As I can tell it's just the motor weight keeping tension. I can lift up the motor and bracket no problem. I'll play with it a bit per your suggestions and see what I can see. Thanks.
    Mar 2020
    5
    Quote Originally Posted by Rob F. View Post
    That's a very good question. I don't really know. Maybe I should replace it just to be sure.
    Aug 2008
    Californeeeah
    1,523
    51
    333
    3/8" handles are hard to find, and sometimes expensive. You could try taking a 3/8" drive socket and welding it on backwards to a short piece flat bar, then attach knob to the other end. I was thinking about doing this when I temporarily lost mine.
    Aug 2012
    4,247
    2253
    1678
    Saw these on ebay looking at something else, with a short piece of 1/2 sq tube/.065 wall it would probably work. (Or any other 1/2" sq drive wheel)
    Spring Loaded Safety Handle Hand Wheel BRIDGEPORT CNC Milling Lathe Made in USA | eBay
  9. #8
    Sep 2015
    Ohio
    1,275
    844
    1285
    McMaster has hand wheels with a plain hole thru the center. Buy a 3/8 square broach and make your own.
  10. #9
    Oct 2013
    netherlands Asten
    1,159
    715
    503
    3/8 drill and a file
  11. #10
    May 2006
    Seattle
    2,059
    47
    399
    You can check belt pulley alignment with a long straightedge.
    Remove the belt(s). Does the motor vibrate when run by itself?
    Belts do get flat spots. Run it for awhile. Another trick is to apply a bar of soap to the edge of the belt while running.
    metalmagpie
