I've never used a lathe, but have been reading up on them a bit. My overall shop skills are mediocre compared to you guys. I want to precisely turn plastic. I want to turn with precision, and there's stuff for which I'll need a vacuum chuck.
First, I don't need to turn things with an accuracy of 0.001 mm, so in some respects a metal lathe would be overkill. However, I will need some precision. Considering a Grizzly 7x12 is made for precisely machining small parts, I'm thinking that this might be the way to go. Also, since metal lathes have tool holders, I'd guess that it's better to use one instead of a wood lathe.
It's my understanding that vacuum chucks aren't made for metal lathes, only for wood lathes. Is it possible to use one with a metal lathe, or are they built too differently? I'd be using VERY low RPM, so there is no chance that the piece would fly off and be dangerous.
It seems to me, that vacuum chucks are a long metal tube for a spindle, attached to a vacuum chuck at the "cutting end", and extend out the "back" of the lathe. I don't know how air is attached to the spindle. I'm guessing it's not attached DIRECTLY to it, but maybe to something that's around it. I don't know how the spindle is turned, either. I'm guessing there's a belt, etc. within the lathe that makes contact with it. Can you fill me in on this?
How well do the vacuum chuck spindles hold true to center?
I wouldn't be working with anything over about 1.5" in diameter for plastic. I might have need of some metal parts too, and I don't know how long they'd need to be. I'm considering the grizzly mini lathe, 7x12. Would this be a good choice? I've heard that these lathes take a little bit of tuning in order to work. Is the tuning something I could do easily, or should I hire someone? I don't have a milling machine.
For basic work, what sort of accessory items am I looking at? I'm guessing I'll need at least three different gauges. Are these items that I can go cheaply on, since I'm not looking for extreme precision? I'm hoping to put as little money into this as possible.
I'm sure I'm overlooking something. If anyone can offer some advice, I'd appreciate it.
