We manufacture a part that is made from 1/2" 4130 tube with an .083" wall. I add several features, part to length and then send them out to be centerless ground to .4995". The problem is that we are having a hard time finding material that is large enough to grind to the final OD, since the entire OD must be ground. Ideally, we would like a .501" OD to start, but it seems like everything we order is on the low side of the tolerance (-.002" or more). For years (36 years and counting!) we have had contacts at suppliers that would measure a lot for us and we would buy the entire run when he found one over .500". We are nearing the end of our supply and need more soon.
Over the years these contacts have passed on and now it seems to be "you get what you get. +/- .005" and all of it seems to be on the small side. We use several hundred feet of this annually, and are not afraid to buy a large quantity when we find it. So does anyone have any contacts that they would care to share who might be willing to source this seemingly boutique material?
Regards, and thanks in advance!
