Need to raise replacement electric motor a little over 22mm
Results 1 to 5 of 5
    Feb 2021
    AUSTRALIA
    Default Need to raise replacement electric motor a little over 22mm
    Hello, I have a silo drier fan that I am repairing.
    I have purchased a new electric motor, but the frame is slightly different - I need to raise it 22.5mm to fit the existing blower fan frame.
    What do people suggest for this?
    I'm leaning towards square tubing with washers to make the difference.
    Jun 2012
    Eastern PA
    1,165
    365
    566
    Pretty much anything of the right size, that is strong enough not to collapse, will work.
  3. Likes digger doug liked this post
    Oct 2005
    22,083
    Quote Originally Posted by awander View Post
    And when you get it right, run a quick weld bead down all the spacers/junk to lock them.
    Apr 2004
    Modesto, CA USA
    8,656
    1660
    The click lock flooring is a nice flat material that can be stacked for thickness. Not great if it gets too wet.
    Bil lD
    Mar 2005
    Kansas
    8,620
    605
    4348
    I would prefer solid. Chances are the tubing will oil can over time and allow the bolts to come loose. Lots of vibration in your scenario.
  7. Likes tdmidget liked this post
