jackal
Titanium
- May 4, 2006
- northwest ARK
I have a customer that has a large wood chipper. The feed rolls on each side have these worn gripper strips that need replacing.
I'm guessing the material is some type of AR plate ( guessing AR400). These straps are 15-1/2" long. They are 1/4 " thick, and stick out 5/8". It looks like metal slats sticking out, and they are skip welded with (probably 7018).
I have a sheetmetal shop quoting the price for using a water jet to cut these plates out.
Could these be sheared from 1/4" AR 400 plate?
Across the top they have a chisel edge to help grab the wooden limbs. My thoughts are that I can use an old carbide end mill to put this edge, and finish with a hand grinder.
I'll try to post some pics.
Having never worked with AR plate, any advice or help is appreciated.
Jack
Jack
