swarfmeister
- Aug 29, 2017
So we have an older SMW Spacesaver 2000 pneumatic bar feeder that we bought used a couple of years ago. Essentially the feeder moves the bar via a longitudinal dual acting air cylinder wherein a plastic coated cable attaches to either side of the piston and then seals via a block on each end that also has fittings for the air inlet/exhaust. The SMW were built in Spain so all is metric.
The cable is about 16 feet long x 4mm in diameter on the OD of the plastic coating, and is thus far unobtainium in the good ole USA. Might one of our Non-US or European comrades be able to help a brother out? Feel free to PM me if you have a source.
Thanks in advance!
Tim
Thanks in advance!
Tim
