Are needle bearing needles hardened?
Page 1 of 2 12 LastLast
Results 1 to 20 of 25
    Aug 2004
    GERMANY
    1,710
    16
    290
    Default Are needle bearing needles hardened?
    I need oversize needle bearing needles and cannot find any.
    So I thought I buy the next size up and grind them down in an OD grinder. Since I need to grab them in a collet I also have to buy them longer.
    So to make 2.55 mm diameter needles I need to buy a 3 mm or even 4 mm diameter needles.
    The main thing I worry about is that the needles may be hardened and that I will grind the hardened layer away.
    From 3 down to 2.55 may not be a problem, but from 4 mm down to 2.55?
    Any input appreciated.
    Martin
    PS I guess the information will be buried in the infinite information of FAG catalog or the likes. But I could not find it .....I never can.....
    Jan 2003
    UK
    869
    464
    435
    Unquestionably they will be hardened. But your question should be are they case hardened (i.e. The surface layer only) or through hardened.
    Dec 2004
    uk
    14,057
    4552
    6705
    Buy one stick in vice, hit with hammer, results should be self explanatory, i would expect it to vary from supplier to supplier.
  4. Likes pressbrake1, Lt. Swarf, Dave G. liked this post
    Jul 2006
    Hillsboro, New Hampshire
    7,835
    1829
    5509
    Are you sure grinding the needles is the best choice? I would look at grinding one of the races to use a standard needle, if that's possible.
    May 2017
    FINLAND
    1,797
    497
    821
    AFAIK custom sized "needles" from SKF were quite reasonably priced.
    And SKF uses trough hardened 52100 for most of the parts, including needles.
    Surface hardened bearing parts or races are more of a Timken thing.
  7. Likes Wild West, Dave G. liked this post
  8. #6
    Jul 2006
    7,835
    1829
    5509
    Quote Originally Posted by MattiJ View Post
    Some time ago I tried to find a vendor for needles and rollers, if you have a specific website for such it would be great to post the link.
  9. #7
    May 2017
    FINLAND
    1,797
    497
    821
    Sorry, can't remember details and it was in any case some local distributor that won't be much of help unless you can speak Finnish
  10. Likes adama liked this post
  11. #8
    Jul 2006
    7,835
    1829
    5509
    Ilmatyynyalukseni on täynnä ankeriaita.
  12. Likes Mstcnc, BugRobotics, MattiJ, tdmidget liked this post
  13. #9
    Apr 2007
    Melbourne Australia
    215
    37
    27
    this place probably has your size in stock, M2 blanks, just cut them to length.
    WILLIAM T. HUTCHINSON CO. HSSBLANKS UNION, New Jersey (N.J.)
  14. #10
    Dec 2004
    uk
    14,057
    4552
    6705
    Not just that but if high speed or high stress they need better than ground finish and the corners need to be just right. FYI Most the big bearing suppliers have direct links to source this stuff you still wont yet find listed on the web, one of thoes few remaining distributor only things. Have never got custom needles, but have got custom rollers.
  15. Likes Milland liked this post
  16. #11
    Aug 2002
    France
    1,636
    292
    656
    Quote Originally Posted by Martin P View Post
    For a Deckel spindle ?
    Can't you ask Franz Singer where he buys the ones he uses ?
    Plus I seem to recall I read somewhere that needles weren't ground perfectly cylindrical on their whole length to avoid stress on the ends.
    Not sure though.
  17. Likes adama liked this post
  18. #12
    Oct 2004
    UNITED KINGDOM
    1,415
    90
    538
    I would have thought that centreless grinding is the way to go for this type of work. Trying to hold them in a collet and grind on a conventional OD grinder seems a bit problematic. Once set up, a centreless grinder could do hundreds in the time it takes you to set one up in a cylindrical grinder.
  19. #13
    Dec 2004
    uk
    14,057
    4552
    6705
    Quote Originally Posted by TNB View Post
    Can't you ask Franz Singer where he buys the one he uses ?
    Plus I seem to recall I read somewhere that needles weren't ground perfectly cylindrical on their whole length to avoid ends stress.
    Not sure though.
    Yep, they can not be simply square ended, theres a lot going on if there too work well and even more if you want to run them even remotely fast and with needle rollers fast is slower than most realise!
  20. #14
    May 2003
    Iowa
    10,492
    3616
    4274
    When I was in automotive, our needles would come from SKF in about a 2 gallon container. IIRC, 70K in each. The needles are centerless ground and lapped. I'm thinking finish was 4 or better.
    JR
  21. Likes digger doug liked this post
  22. #15
    Feb 2010
    ch
    2,100
    194
    274
    i keep hearing about oversized balls, but when i wanted to get some recently, my skf supplier didnt have any. there were balls in many sizes, but not oversized like + 0.01 mm.
  23. #16
    May 2012
    Pittsford, NY
    1,054
    724
    680
    I know nothing about the application, but a .1" needle is .00039 oversized. Do the rollers come in decimal inch sizes?
  24. #17
    May 2017
    FINLAND
    1,797
    497
    821
    Quote Originally Posted by wheels17 View Post
    Inch sizes are available but usually in 1/16” multiples, not 1/10”
  25. #18
    May 2003
    Iowa
    10,492
    3616
    4274
    It all depends on quantity. If you buy enough, you can get almost anything you want.
    JR
  26. Likes SVE Performance liked this post
  27. #19
    Jan 2005
    CANADA
    Saskatchewan
    10,236
    1394
    3688
    Quote Originally Posted by dian View Post
    Check precisionballs.com
  28. #20
    Feb 2006
    Indiana
    12,979
    689
    3928
    Much depends upon the application, which was not stated in post #1.
    I needed a 3/16" diameter x 3/16" hard roller for a B&S releasing tap holder last week. In my drawer of 3/16" steel dowels are some 3/16" bearing needles with a polished finish and rounded ends. I used one to make my roller. I put it in a 5C collet in a Hardinge lathe and squared one end with a carbide bit. Then I used a carbide P1 cutoff bit to cut off a little more than 3/16" and faced that end to the final length. The needle was hard all the way through, but carbide could cut it at high speed.
    Many years ago, I wanted to try needle kingpin bearings in a 12,000 pound front axle for a heavy truck. That was what you might call a low RPM application. The stock bushings were 1/16" wall, the king pin was hardened steel with a centerless ground finish. The knuckle was forged steel with reamed kingpin holes, not very hard in that part of the knuckle. I bought a few dozen 1/16" drill blanks and they worked well enough to try out the idea.
    HS drill and reamer blanks are available in many diameters, but they do not have polished surfaces and the diameter tolerances are probably more loose than bearing needles would have. Not important if you have to reduce the diameter, and the key thing is that you would not need to reduce it very much.
    Larry
