A new challenge...shortening screws
Page 1 of 2 12 LastLast
Results 1 to 20 of 37
    Jun 2002
    CANADA
    British Columbia
    2,756
    2380
    Default A new challenge...shortening screws
    Good morning All:
    So I just got a new project this morning...I have to shorten some screws...some LITTLE screws...120 of them!
    I have to take about 0.5 mm off them and they all have to be the same within about 0.05 mm (0.002")
    I'm thinking a U shaped steel bar with 40 holes tapped into them and a quick whirl on the surface grinder.
    I want the heads of the screws to touch the mag chuck so they'd go between the legs of the U, and if this turns out to be the best way, I need to make the feet of the U big enough so they'll stick to the chuck.
    I want the screwheads to touch the chuck so they can't back up when the wheel hits them.
    I am free to stone the heads if I have to in order to get them all to touch the chuck.
    Problem is, it's all so skinny I'm afraid the heat from the grinding is going to suck the jig plate up into the grinding wheel.
    So I thought maybe 40 counterbores into a thicker plate, but now the jig is getting to be more work than the screws.
    Any brilliant ideas out there??
    I do have a sinker and a wire EDM but I can't see a way to avoid having to make the fixture, even if I use one of those machines to eliminate the spinning screw problem that comes with the grinder.
    Sorry about the blurry pic...the screw is so damn tiny it's hard to keep it from rolling off my finger when I put it under the camera lens, so I wasn't all that steady when I tripped the shutter.
    Cheers
    Marcus
  2. Likes DrHook liked this post
  3. #2
    Mar 2019
    Minnesota
    44
    26
    16
    You are on the right track with c'bored holes in thicker plate. I would do it 10 at a time since I hate tapping small holes and would rather spend the time changing screws and grinding. That looks like a whole lotta no fun!
    May 2019
    Michigan
    1,470
    425
    671
    What are those things going to cost when you're done??
    Jun 2002
    CANADA
    British Columbia
    2,756
    2380
    Hi ChipSplitter:
    You wrote "What are those things going to cost when you're done??"
    I don't know and I don't care.
    It's a cost plus job and the customer is working with a multi million dollar grant from the Canadian Government, so I'm really lucky to have been able to attract these guys as my client.
    Let's just say they're spending freely at every high end shop in Vancouver...I'm a small player with what they call "Special Skills" so I get called for the weird shit nobody else wants to tackle.
    'Tis a good gravy train...I'm fortunate to be on it for now, so I'm gonna deliver the best value I can for as long as I can.
    Cheers
    Marcus
  6. Likes morsetaper2, DrHook, sfriedberg, steve45 liked this post
  7. #5
    Sep 2015
    Ohio
    1,301
    862
    1305
    What about a tapped and c'bored block? Screw the part in from the side and as the threads come out the far side they go up against the side of your grinding wheel.
  8. Likes doug925, Joe Miranda, JohnMartin liked this post
  9. #6
    1,793
    103
    73
    Quote Originally Posted by implmex View Post
    Hi ChipSplitter:
    Cheers
    Marcus
    Use a lathe type of machine. Put screw in collet,bring forward tailstock to steady screw and face to length.
    ailstock
  10. #7
    Jun 2013
    Buffalo NY USA
    515
    338
    273
    Those are the best kinds of customers, eh? Fortune favors the prepared.
    I looked at your pic and almost screamed. Better you than me.
    I guess "small" means different things to different people.
    I think you're on the right track with a thick plate, drilled, counterbored, and tapped, then skim the whole enchilada on the surface grinder in one go.
  11. #8
    May 2019
    Michigan
    1,470
    425
    671
    Quote Originally Posted by pavt View Post
    That's what I thought, too.
    Ah well, nothing like goobermint money.......
  12. #9
    Jul 2002
    Maryland
    4,462
    791
    655
    Make sure you sweep the floor in the area you are working. Although I know you won't drop any on the floor, right?
  13. Likes pavt, Bobw liked this post
  14. #10
    Feb 2006
    Indiana
    13,192
    727
    4119
    Thirty-five years ago, I had to shorten a couple hundred 0-80 x 1/8 socket head cap screws to about 1/16". The length tolerance was not stated; they just had to screw into a 1/16" thick gun sight and not stick out the far side. The screw head was a stop for the sliding part. No need for a chamfer on the threads, of course.
    I drilled several .060 holes in a piece of 1/16 steel. A screw was inserted in each hole and a piece of leather was used to hold the about to be hot screw heads tight against the steel holder with a finger. Then I held the assembly against my 1 x 42 belt sander for a few seconds, all it took to grind off the excess length of the tiny screws. Got the job done in less time than tapping a bunch of tiny holes in a fancy fixture for my surface grinder or using the Levin lathe with lever cross slide.
    That pan head screw in the OP's picture does not grip nicely in a watch lathe collet, so I don't see using a lathe to shorten them. Watchmakers do have special tools for holding a screw while shortening the threaded end, but they are not suited to doing large quantities.
    Larry
  15. Likes Bobw, cyanidekid liked this post
  16. #11
    Jul 2006
    Hillsboro, New Hampshire
    9,273
    2198
    6434
    The edge break issue is still present. Here's a really nuts idea - take a carbon electrode and mill a blunt-ended cone in it that matches the screws minor diameter at the small end, and flares a little bigger than the thread OD. You can do this to the side or bottom of the electrode, depending on how you want to orient the other part.
    make a plate with a hole(s) that matches the OD of the screw thread into a vise standing vertically or horizontally to suit the electrode. Have a thin stainless shim on a screw pivot such that it can slide over the head of the screw, capturing it.
    Now you can plunge or orbit your electrode over the screw thread, removing the excess length and leaving a chamfer behind. Adjust number of holes in electrode/plate to whatever makes sense.
    Bingo (or whatever you Canucks say) - shortened screw, chamfered thread, job milked, invoice massive.
  17. Likes LockNut, mountie liked this post
  18. #12
    Nov 2002
    3,321
    1962
    838
    I have done the same on 250 pcs of a 3mm machine screw.
    Had to shorten them to a tightly controlled length. (about the same tolerance of the OP)
    I went with 2 fixture plates, with 50 screw locations each.
    That way I could machine a set, while loading the next. (loading the fixtures took much longer than the 1 minute machine time.)
    As stated above, screw the screws in from the bottom of a (machined on all sides) fixture plate.
    When you back them out, it will repair the starting thread.
    Fortunately, we did not have to put a chamfer back on the starting thread.
    Could you use a face mill, followed by a 45° chamfer mill to chamfer each screw in the plate?
    The ends of the screws would either have to be proud of the plate, or a c-bore with enough clearance to allow for the end mill to chamfer the parts.
    Just my $0.02
    Doug.
  19. #13
    Mar 2019
    UNITED KINGDOM
    207
    40
    Personally, I would make a block with counterbores and rather then tap the hole, just make the hole pretty damm close fit on the screw so that after the heads are stoned, you can pull them back to a mag chuck well. As if they are threaded, it’ll be a pain to screw them back to the mag chuck.
    If your taking 0.5mm from nominal make the jig 0.6mm under nominal.
    I would also mount the mag chuck on the WEDM and wire the front off. That way you will make the smallest burr compared to grinding. Do you have to put a chamfer/lead back on after? Or just leave able to thread?
  20. #14
    Feb 2005
    9,262
    14980
    11109
    I had one screw shortening job years ago. It was a small screw, maybe a 4-40,
    HUGE compared to your screw, but still small.
    Instead of tapping my fixture for the small screw, I drilled through at the major
    diameter, then drilled the backside bigger and tapped it, and used a 3/8 set screw
    to hold the tiny little screw in. It was just easier to handle a 3/8 screw than
    trying to hold and start the little screw. And I could crank it down a lot harder,
    to make sure it didn't move.
    That looks like a miserable little job.. No pun intended.
  21. Likes MattiJ, Joe Miranda, doug925, Leadfootin liked this post
  22. #15
    Jun 2013
    Buffalo NY USA
    515
    338
    273
    I think it's pronounced "Molson!" (hat tip to Bob and Doug McKenzie)
    I've seen clockmakers tools that put a chamfer on the end of screws, kinda like an inside-out countersink. Just a piece of HSS round, with a couple of 90deg vees milled in the end at 90deg to each other. Stick it on the screw end, give it a twist, and instant chamfer!
  23. #16
    Jun 2012
    Michigan
    11,669
    3983
    4150
    I once did a fussy length screw job but not that small and they were Allen heads so that made the job easier with my jig...A block that set on the magnet with having a vertical portion just a tad less wider than the screw length spec.
    With the fixture block I put each screw through the hole it being the major screw diameter +.001.
    Turning the screw while side wheel grinding so to take away the burr and make size I held .002 easily ..then taking the screw out I brushed each to a rag wheel to make a small bevel, with taking from the grinder to the rag wheel in one motion...so an hour to make the jig and an hour to run the job.
    Agree screws that small can be a problem..to take .019 0r so.
    Yes I could have locked the table and run the screws to the wheel OD on the right side with the wheel .o20 above part center so to get de-burr, and almost flat.
  24. #17
    Jun 2002
    CANADA
    British Columbia
    2,756
    2380
    Hi All:
    Some great alternatives here, and I'm going to shamelessly steal from every one of them to get to my goal.
    So here's my new thinking:
    1) I'll make 10 spots instead of 40 per EOLSON's suggestion in post #2
    2) I'll drill for the major diameter and not tap per L Vanice, Luke.kerbey, Bobw, and michiganbuck.
    3) I'll threadmill the counterbores for 8:32 setscrews to touch the screw heads and I'll get nylon tipped setscrews also per Bobw.
    4) I'll kiss them on the wire EDM per Luke.kerbey to avoid the burr I'd get from grinding them (They won't need them chamfered, Milland, but that's a GREAT idea if they did!)
    So now to get my fat ass in gear and go make a noise !
    Cheers
    Marcus
  25. #18
    Jan 2007
    Flushing/Flint, Michigan
    8,779
    470
    7215
    I do some but not this small.
    Screw them into plates and grind.
    Before removing I hit them with a silicon carbide nylon filament brush wheel which leaves an nice .002/.005 or so radius on the lead thread.
    For me screwing them out leaves an upset burr which makes them not start nicely in their new home.
    Bob
  26. Likes Joe Miranda liked this post
  27. #19
    Mar 2009
    5,602
    103
    1084
    I do those once in a while. Not in big batches.
    Make a thick coin with a threaded hole in the center.
    Insert your screw with the end sticking out the other side.
    Add a back-stop to a coin sized collet and insert coin.
    Face screw with parting tool or tool bit.
    Dress emd of thread with file at 30-45 degrees.
    Repeat with next screw.
  28. #20
    Oct 2010
    Dewees Texas
    2,593
    29
    760
    Looks like we have all shortened commercial length screws. I have never seen the need for many tapped hole fixtures. You still have to screw each one in and out. Done several of that I used a 2 fixture set up, while one is running screw remove and replace the other. The ones in the photo were 1/2 long button heads shortened to .135 long. The socket was clamped to the bench next to the machine. My secretary did more than I did and she could and got so she had no lost time, ready to load the next part as soon as the part came out of the collet. Smaller ones were done the same.
