stoneaxe
Stainless
- Mar 2, 2010
- pacific northwest
Making an end mill holder-- it was first bored in place in the machine spindle,(on horizontal axis ) then reamed to size with a fixed reamer held in the table vise.
To establish the reamer on hole center, first, the reamer was secured in a vise with the shank indicated in within a couple of thou of parallel with the tables travel.
I ran the table forward so the reamer shank was parallel,but not touching, the OD of the endmill holder. Then took the space between them, plus half the diameter of the holder and reamer shank, and used it for a zero point. Did the same on the vertical axis. Purely a math solution.
Nevertheless, the end of the reamer was about .005 off center.
Maybe it was an accumulation of error, or perhaps the reamer shank was not dead straight, etc- finally I put an indicator on the end of the reamer, and zeroed in the movement (with the end having chamfer, it would move when entering the bored hole.) This may have been a mistake, if the point where the reamer was held in the vise was on center, and the "off center" at the hole entrance was because of a slight bend in the reamer shank.
Anyway, the hole was successfully reamed. I think flex was my friend.
The point of all this, is the question-
Using a measuring device, what is the way to locate the hole center in the spindle, and the same point on the table/vise/reamer setup? I could easily locate either one of them, but the indicator needs to move to locate the other, losing zero in the process.
