Newbie with Collet Issue
Results 1 to 12 of 12
    Aug 2019
    CANADA
    Newfoundland and Labrador
    Default Newbie with Collet Issue
    Hey All
    I am new to the world of milling, but I decided to give it a go. (I am a longtime knife and pen maker, who will mainly be using it to machine knife guards, handle cutouts and other simple tasks.)
    I have a King KC-20VS-2 milling machine. I believe this is a common cheap milling machine that has multiple clones, such as the Craftex CX601 and multiple others.
    Here is a link to the King Machine I have:
    Milling drilling machine with digital readout KING Canada - Power Tools, Woodworking and Metalworking Machines by King Canada
    And here is a ink to my R8 ER32 Collet system:
    https://www.accusizetools.com/0223-0...with-r8-shank/
    My question is simple. While the R8 chuck (collet holder) fits the machine, I cant figure out how to tighten the collet retaining nut to the required specs. My machine doesn't seem to have a breaking system, so the spindle just turns freely.
    Am I missing something here?
    Thanks for all your help. Reading this forum has been a lifesaver!
    Feb 2006
    Indiana
    13,331
    746
    4229
    The obvious question you left unanswered is, how do you tighten and loosen the drawbar for your R8 chuck? If you can tighten the drawbar, then the same method should let you tighten the ER32 collet nut.
    If you can't answer that question, then I can only suggest you mill or grind a pair of wrench flats on the R8 chuck body, in the area near the etched size marking. Make it fit a large open end wrench of whatever inch or metric size seems appropriate.
    I guess you know that "real" milling machines have spindle brakes or locking pins to make changing the R8 tooling simple. They do not depend upon an 8mm wrench to hold the spindle against normal R8 tightening torque. Yes, I read your machine instructions. I expect that 8mm flat to get rounded off if you have to use it for normal tightening.
    Larry
    Jan 2013
    Plainfield, Indiana, USA
    1,816
    1399
    963
    How do you tighten the R-8 collet?
    (Guess I type too slowly)
    Aug 2019
    CANADA
    I tighten the drawbar for the R8 chuck using an 8mm wrench at the top of the unit. Another locking nut then tightens over it. According to the manual, the 8mm nut should only be hand tightened and the locking nut just snugged.
    Here is a picture of the assembly under a small cap on top of the unit:
    Feb 2006
    Indiana
    13,331
    746
    4229
    You know that keyway in the shank of the R8 tooling? It is not what drives the cutting tool. It is there as protection against damaged threads in the collet or drawbar creating too much resistance to removing the tool in the normal way. In fact some "real" mills don't even have a pin to engage the keyway. What drives the cutting tools is friction on the tapered part of the R8 tooling, so that drawbar had better be a lot more than "snugged." Once the tapered surfaces slip and spin, the pin (if present) shears and the spindle is wrecked. R8 tooling is cheap, so small loss there, but spindles are not cheap. And that is why the drawbar has to be really tight. I bought my mill new in 1974 and it was built with no collet pin. It does have a spindle brake and the drawbar has a 13/16" hex for the wrench. I use a normal length 3/8" drive ratchet on it, not a long combination wrench. I have never had an R8 tool slip in the spindle.
    Larry
    Aug 2019
    CANADA
    Ok, that makes a lot more sense to me now.
    So the 8mm nut that screws the R8 arbour up into place and the larger drawbar nut then forces the angles of the tooling together to make a "friction connection." Similar to how a MT1 or MT2 wood lathe would work, but pulled much tighter by the draw bar then the drawbar nut.
    That actually makes the whole think make sense to me now.
    It's also good to see a normal 3/8 ratchet will make it tight enough. Seems like a good tight fit will work without wailing on it.
    Jun 2012
    Idaho
    3,180
    1758
    2089
    I have never ever used the spindle brake to loosen or tighten the draw bar..Stik it in low and figure it out
  8. Likes Leadfootin liked this post
  9. #8
    Dec 2008
    IL/WI border
    3,432
    1234
    1068
    Remove the pin (key) from the spindle and discard it before using the mill. You don't want to give it any chance to shear.
  10. #9
    May 2011
    New Jersey
    2,581
    235
    1398
    Quote Originally Posted by MichaelP View Post
    Didn't check out the link eh? That mill would have trouble breaking a child's plastic key let alone steel
  11. Likes MichaelP liked this post
  12. #10
    Dec 2008
    IL/WI border
    3,432
    1234
    1068
    Quote Originally Posted by plastikdreams View Post
    Do you say the key is not plastic?
  13. #11
    Jun 2012
    Michigan
    12,130
    4097
    4348
    You might try a strap wrench.
  14. #12
    May 2011
    New Jersey
    2,581
    235
    1398
    Good point!
