Mud
- May 20, 2002
- South Central PA
Had an experienced rebuilder recommend I use pure nickel shim material to correct the fit of shell type plain bearings in a machine because that's how he does it. Another says brass or steel would be OK but he hasn't actually done it
Think of a situation similar in size to the main bearings or rod bearings in an auto engine, about 3" diameter and 2" wide. I need to change the fit by .014 on the diameter to get the correct crush, so I'm considering using .007 shim in the saddles. The alternative is a new iron casting, other methods of refit are not practical here because of tight clearances and the way the machine is constructed. Oversize bearing shells are not available.
This NOT an auto engine, don't lecture me on engine bearings please.
Nickle is hard to find and very costly in the amounts it is sold in. I'm wondering where nickel shim is commonly used or what it's intended to be used for, has anyone here used it for a specific purpose?
Copper shim is also soft and conformable and conducts heat well, since it's a lot more available and much cheaper (hundreds$) I'm looking at using it instead of the nickel.
Thoughts? Experiences?
