Forrest Addy
- Dec 20, 2000
- Bremerton WA USA
Look at this video where the guy repairs a worn motor armature shaft. The narration is heavily accented but bear with it. His words are gold.
Electric Motor Shaft Repair | With Lathe, Welding Machine and CNC-Mill - YouTube
Pretty routine. Turn down the worn area to clean metal, weld up the keyway, then weld build up the diameter, rough machine to 3 mm oversize, then check the set-up and refine the armature to run true. Note he's using a well-used three jaw but has to get the bearing fit at the chuck end to run true. He padded the jaws with copper an excellent choice because copper is malleable.
Note the action and discussion at 4:14. He uses a soft brass punch to tap the jaw. The shock seats the jaw a trifle deeper in the copper moving the armature axis TOWARDS the hammer. Tap succeeds tap, snugging the jaws as you go, and soon the three jaw error has been adjusted out. NEAT trick if the work has mass you can work against.
Afterwards he uses a steady to re-tool the shaft center. Then goes on to finish nachine the shaft to size concentric to the bearing axes, machines the keyseat, etc. Not a thing wrong with his technique. Brisk but careful.
I've been nearly 60 years in this trade and have never seen that three jaw trick nor worked it out for myself though I could have used it a zillion times. Goes to show there's always a new trick even when you think you've see it all.
Hat's off the the Beyond the Press guys. Glad to see they can be skilled workers when necessary and not just YouTube clowns.
