WayneC369
Hot Rolled
- Jan 4, 2014
- ATL, GA, USA
BACKGROUND:
I was asked to mfg some small press rollers approx 40mm OD x 40mm lg. For trial purposes I made six each of these things with a steel tube core, straight knurled the OD end to end which increased the OD by 0.020" - 0.022". Then turned and bored a nylon sleeve with a 1.000" ID and pressed it over the core. I didn't hear anything of them for a few months then I get an RFQ for 50 of the same with a request to sharpen my pencil. The money we're talking about here is absolute chicken feed to begin with, so I made a change to the design which I thought to be minor yet allowed these things to be churned out on my CNC lathe. All ops except the knurl which was done manually. The change was instead of knurling the entire length of the core, stop 6mm short of the ends so as not to disturb the close tolerance bearing bore. I thought this to be a major requirement since one of the customer's complaints was a gritty bearing feel from a competing vendor. (FYI - the other vendor(s) are peddling rollers of differing materials.) Well it seems this change has bitten me in the ass. It's now over a year later and they are asking for the original version as the nylon sleeve won't stay on the core in the batch of 50 as did the first batch of 6. BTW - I offered to build with a retaining ring at each end and the offer was rejected... go figure.
QUESTION:
I've yet to see this process and getting information from the engineers is akin to eating tomato soup with a knitting needle. The ONLY bit of information I have been able to ascertain is the product temp this roller is in contact with (almost 100% duty) will see a max of 125°C ( 257°F). Is anyone here with thermal experience that can/will check my numbers and let me know if I'm figuring the expansion correctly?
I have gotten this data from my vendor re: Nylon 6/6 coefficient of thermal expansion to be 0.000055 in/in/°F. I'm SWAGing a delta T of 187°F in which case the nylon would grow ~0.01028". I am basing the expansion of the steel core on a rate of 0.0000075 in/in/°F. With the same delta T the core would grow ~0.00140".
Therefore, I should still have approx. 0,010" of interference fit.
QUESTION:
