Hey guys!
So I currently have a DevAir II PAFCTV660V3. It's a 6hp 60Gal twin oil less and boy is it noisy. I've been offered an older barely used Devair PCI-560 5HP 60Gal twin, which seems to run so much quieter. Electrical motors have pretty much the same rating with the exception of amps in that the older compressor has a max of 16Amps whereas the newer compressor is max 14Amps. Both are 230V. I can't find any info whatsoever on the older PCI-560 in terms of max PSI/cfms etc. I can only keep one so I'm wondering if you have any advice? I've bled it - nothing major and comes out clear. I'm wondering if this old twin is a much better machine than the new noisy V Twin. I've attached some pics of the older PCI-560.
Thanks for any advice!
Davey
Davey
