I'd like to add an RPM sensor to a simple Raspberry Pi Pico powered motor controller. I'd like to use a notch or teeth in a steel motor coupling and have a board mounted sensor pick up on that notch to read reliably through 7000+ RPM.
Like what an ABS wheel sensor does or a crank or cam sensor in an engine, only I'm looking for something that I can surface mount directly on a board. I don't want to attach any magnets. Sensor can be 5V or 12/14V. Accuracy is not critical. Low cost and in stock/available are the primary requirements. Whatever the output signal is my electronics guy can make it work.
Any suggestions? Even just a brand name or correct nomenclature for what I need?
Thanks!
Thanks!
