O/T - Safe flywheel speed?
Page 1 of 3 123 LastLast
Results 1 to 20 of 48
    Oct 2005
    CANADA
    Ontario
    1,222
    296
    437
    Default O/T - Safe flywheel speed?
    Trying to figure out a safe rpm limit for a steel flywheel 6" diameter x 1" thick. I'll turn it from solid so the shaft and wheel are one piece.
    Machinery's Handbook (27th Edition) has a formula on pg. 191 in the "Mechanics & Strengths of Materials" section called "Safe Speed Formulas for Flywheels and Pulleys". This says a max of about 17K but it only shows steel with 60 ksi tensile strength and doesn't give the safety factor. I'm planning to use 4340 which is around 160 ksi. I'm hoping to turn it to 30K briefly for use in a small inertial dyno.
    Any material engineers here? Anyone point me to some more detailed information?
    Jul 2006
    Hillsboro, New Hampshire
    8,909
    2139
    6160
    How well it's supported and how well balanced it is will influence the maximum safe speed. How are you dealing with those two aspects?
    Jul 2006
    8,909
    2139
    6160
    May 2009
    Canandaigua, NY, USA
    3,000
    151
    1373
    Basic formulas and a reference here- Solid Disk Flywheel Design | Engineers Edge | www.engineersedge.com
    I'd also thing balance will have to be dead perfect and you also get into critical speed of the shaft and such. In any case you want a suitable safety containment device. That will probably cost way more than the flywheel.
    Mar 2011
    Geneva Illinois USA
    6,426
    2807
    2509
    Rather than going for more speed, put more material in the rim.
    Tom
    Aug 2004
    Virginia
    2,454
    179
    971
    Watch out for precession forces on your bearings and shaft as well.
    Mar 2007
    Milwaukee
    444
    346
    208
    One thing to think of as well is you spindle and its design and manufacture. You'll want every tolerance on your shaft to be a tenth or so. And perfect fits on your bearings. For balancing i would recommend a shop that rebuilds turbo chargers.
    One surprising thing about bar stock is that even parts within a tenth are not balanced.
    Jun 2001
    St Louis
    18,338
    2007
    3153
    Quote Originally Posted by TDegenhart View Post
    Tom
    Good idea from the safety point of view..
    Problem is, "V^2" goes up a lot faster than "m". The payoff for more speed is just way better, especially if weight is a consideration, and it usually is.
  9. Likes TDegenhart liked this post
  10. #9
    Mar 2011
    Geneva Illinois USA
    6,426
    2807
    2509
    Quote Originally Posted by JST View Post
    ..until it blows up from over speeding.
    If this is more than just a simple flywheel, then its time to pull down the design books. Years ago there was "push" for flywheel powered vehicles. A lot a time was spend designing the optimum shape and construction.
    Tom
  11. #10
    Oct 2005
    CANADA
    Ontario
    1,222
    296
    437
    Will be supported solidly with pillow blocks. Going to turn it between centers so it should come out close but will check the static balance carefully before running it.
    Glad that guy changed his mind. 1000 lb flywheel at 10K, ya right.
    Anyone here run a Solidworks simulation like in that second link?
    Quote Originally Posted by Conrad Hoffman View Post
    That's what I was looking for, thanks! Anyone care to check my calculations? Using that formula at the bottom of the page I get like 184.4 N/mm2, that's only about 26.7 ksi, seems way too low to be right.
    Plan to build a solid steel (1/4" plate?) box around it, don't want to be hit by 8 lbs of steel bouncing around the room!
    I could gear it to slow it down but direct drive is so much simpler, and accurate. I could go to 5" diameter and 2" thick for the same inertia effect or 4" and 5" long but the weight goes up a bunch.
  12. Likes plastikdreams liked this post
  13. #11
    Aug 2014
    bainbridge island
    1,241
    257
    292
    Rotor diameter 11.2 cm
    These folks tested their prototype to 60K rpm but there is no mention of if they hardened the 300M steel rotor.
    http://power.eecs.berkeley.edu/publi...yPhDThesis.pdf
    Ultimately, 300M alloy steel was selected for the rotor. The low alloy steel 300M is
    very similar to AISI 4340 in composition and can be hardened to an ultimate strength of 2.0GP a
    (290ksi) and has a fatigue strength of 1.0GP a (145ksi) for over 1 million cycles [1]. It was
    chosen because of its high strength, availability, and relatively low cost.
  14. #12
    Jul 2011
    Americus, Georgia
    428
    544
    134
    You need professional assistance. Pillow block bearings? Shaft material and diameter. Unidirectional bending fatigue calculations at your projected cycles. 1/4 inch shatter shield. But its your dream so go for it, but with caution.
  15. Likes Rudd liked this post
  16. #13
    Oct 2005
    CANADA
    Ontario
    1,222
    296
    437
    Quote Originally Posted by muckalee View Post
    Ya, I hear you. But professional engineering will put the project way over budget, lol.
    A few of these have been built and I haven't heard of any coming apart but they've mostly used lower rpm and/or smaller wheels so it's the wheel I'm worried about. Pillow blocks will be custom made with drip oilers and Swiss bearings that have been proven to handle that rpm. The base will be 3/4" MIC 6, I'll use Thompson "60 Case" 15 mm for the shaft, a clutch and one-way bearing. I'm pretty confident all this is OK, it's just the wheel I'm worried about. It'll look similar to this:
    Anyone care to check my results with this formula?
    p = 7800
    u = 0.3
    v = peripheral velocity in m/s. My wheel is 152.4 mm in diameter at 30,000 rpm.
  17. #14
    Nov 2004
    WI
    4,741
    504
    1101
    Do you follow two stroke stuffing on Youtube?
  18. #15
    Apr 2004
    Modesto, CA USA
    7,362
    1280
    I think you have the wheel and mounts pretty well understood. You seem to be ignoring the stuff that drives it. High rpm flex coupling, gears, pulleys etc have not been mentioned. I hope it is not chain drive.
    Bil lD.
  19. #16
    Nov 2018
    Michigan
    384
    180
    214
    Quote Originally Posted by Terry Keeley View Post
    p = 7800
    u = 0.3
    Question on your "v" term. How did you get the 0.35? I have:
    Rotations * (pi * diameter) meters * minutes
    aMinute aasdeterf rotation asdasdff second
    (30e03) * (152.4e-03 * 3.1415) * (1/60) = 239.39 which is much higher than your 30*0.35 = 10.5
  20. #17
    Oct 2005
    CANADA
    Ontario
    1,222
    296
    437
    Quote Originally Posted by 3t3d View Post
    I'll have a look thanks but it looks like mostly gas stuff, I'm all nitro.
    Quote Originally Posted by Bill D View Post
    Bil lD.
    Want to stay away from gears/chains/pulleys and go direct drive for simplicity and to avoid the losses from them.
    Thought initially to use some rubber "lovejoy" couplings but don't think they'd be balanced and accurate enough at 30K so going to make my own solid 7075 set screw couplings. Everything will be accurately aligned then dowel pinned to maintain alignment.
    Quote Originally Posted by BoxcarPete View Post
    Thanks for checking. The 0.35 is just the example given, their wheel is 350 mm in diameter and is turning at 0.3 rad/sec. You got the same O/D velocity I did tho at 239.4 m/s. Do you end up with 184.4 N/mm2 or 26,700 psi?
    Again, it seems way too low considering Machinery's Handbook said I was way over-revving it with 60 ksi material.
  21. #18
    Feb 2013
    Northern califorina, usa
    282
    86
    Wow, I sure would build some type of scatter shield for this thing, even small components at that RPM will launch a long way.
  22. #19
    Dec 2012
    Se Ma USA
    1,705
    136
    928
    Im scared, you should be too.
  23. #20
    May 2013
    wi usa
    196
    61
    I race and build two strokes. The 2 stroke dyno shop I been in on the high rpm stuff uses a timing type belt reduction, so dyno spins at 1/2 rpm of engine rpm.
    p = 7800
    u = 0.3
