O.T. Thermostat Query.
Page 1 of 2 12 LastLast
Results 1 to 20 of 21
    Apr 2009
    Beaver County Alb. Canada
    1,850
    533
    906
    Default O.T. Thermostat Query.
    Ok so Cummins want $110 for a Thermostat for my Mustang Skidsteer , can one not just match the dia. and temp and use any Thermostat ? I dont see why not !
    Feb 2007
    St. George, Utah
    853
    381
    541
    You probably could, but some have a small vent hole to allow air to escape. That can be important because an air bubble around the pellet will prevent it from sensing heat properly. In addition, quite a few these days come with an integral silicone seal . You'd need to make sure any substitutions would seal properly in the recess. Other than that, as far as I know if it fits it ought to work.
    Apr 2009
    1,850
    533
    906
    Yes it has the small vent for air bleed, Ill see if I can match it up with an aftermarket one and see thanks.
    Apr 2004
    Modesto, CA USA
    6,798
    1131
    Do they make thermostats that are in line inside a hose? Seems like you could make a simple housing for one and make it fit somewhere that way. Maybe as simple as two water necks back to back. I believe it is under 14 PSi. or maybe it is 7 PSI?
    Bil lD
    On edit they do make remote thermostat housings. Cheaper then your replacement thermostat.
    JEGS In-Line Thermostat Housing | JEGS
    Apr 2004
    Modesto, CA USA
    6,798
    1131
    I do not quite know why but they also can replace the water pump with an electric one. Maybe vary the speed regardless of rpm?
    Bil lD
    Aug 2012
    California, Central Coast
    3,399
    2164
    1323
    Quote Originally Posted by Bill D View Post
    Bil lD
    Coming from Jegs I would expect the thinking is no engine HP is used/wasted to pump the water. More hp to the tires.
  7. Likes Bobw liked this post
    Oct 2005
    14,852
    Quote Originally Posted by redlee View Post
    Yup, that hole is veeeery important....if you find one without, you might slip it into a flat rate box and mail it off to a member here to get that hole drilled....
  9. Likes Bobw liked this post
  10. #8
    Oct 2005
    14,852
    Bil lD
    Uh bill ?
    OP stated it's in a "Mustang Skidsteer"....have you ever looked in the back of one of these ? with the Cummins stuffed in there, it's a tite fit.
    No need to re-engineer for a cheaper thermostat (recall dealer has proper OEM for $110)
  11. #9
    Apr 2009
    1,850
    533
    906
    Uh bill ?
    Yup, Im not going to re-engineer for $110. I will buy from Cummins if I have to, im sure its a $10 dollar part to them though.
  12. Likes digger doug liked this post
  13. #10
    Apr 2009
    1,850
    533
    906
    Can you recommend another member thats capable ?
  14. Likes digger doug liked this post
  15. #11
    Nov 2005
    Hudson Valley, NY
    968
    589
    Which engine do you have?
    Do you have the Tstat part number from cummins?
    Google the part number and you will find suitable alternatives.
  16. #12
    Feb 2014
    Sunny South West Florida, USA
    2,762
    10448
    3191
    Gordon B. Clarke
    He bores most of us, he oughta be able to bore a hole.
  17. #13
    Apr 2009
    1,850
    533
    906
    Cummins no.
    3800884
    I tried didn’t find any
  18. #14
    Apr 2004
    Modesto, CA USA
    6,798
    1131
    The hole location is also important if the thermostat main plane is vertical the hole normally goes up. If the thermostat lays flat hole location should not matter just as long as there is a hole.
    Bill D.
    PS: No i have never seen inside a skid steer engine compartment. On Diesel tractors there is plenty of room to modify stuff on the engine. Older Yanmar's did not even have a water pump just thermosyphon. They have issues on a constant slope so folks add electric pumps if their land is not flat.
  19. #15
    Nov 2013
    Eastern Massachusetts, USA
    4,141
    4450
    4327
    I highly recommend a Stant Superstat if you can find one the right size and temperature. Best thing I ever installed - fast warmups and very stable temperature control.
    The Superstat varies the opening with temperature rather than being simply open or closed.
  20. #16
    Jan 2007
    Florida
    1,110
    133
    404
    Cummins no.
    3800884
    https://www.ebay.com/sch/i.html?_fro...acat=0&_sop=15
    from 39.99 to 76.28 took just seconds to find
  21. #17
    Oct 2009
    Oregon
    4,133
    4440
    2084
    The 3.3 is not a Cummins engine. It's made by Komatsu.
    Cummins and Komatsu had a deal then Cummins came out with their own little plastic ISF engine and dropped Komatsu. Cummins does a terrible job of supporting the 3.3 stuff.
    Komatsu should be better on parts.
    The 3.3 is a good little engine though.
  22. #18
    Oct 2005
    14,852
    I figured it was the same as the case skidsteer, was it a 4bdt stuffed in them ?
  23. #19
    Apr 2009
    1,850
    533
    906
    Quote Originally Posted by cg285 View Post
    Exchange rate plus shipping plus 2 weeks to get.
    Almost the same price as I can buy here. Im in Canada and Ebay sometimes is a pain, shipping , exchange , duty, customs and returns are the same. I cant wait that long for parts sometimes.
  24. #20
    Apr 2009
    1,850
    533
    906
    Quote Originally Posted by Garwood View Post
    Regardless who made it its badged Cummins . Thanks I will look into thast.
