Thought maybe there were some fellow tinkerers who'd worked on one of these little window units before.
Little GE 12,000 btu that belonged to some meth heads who abandoned the house they had rented. I've took this apart and tried to get the filthy human and garbage smell out of it. Tag shows made in 2016. Real good shape except for the stench.
Digital soft key control pad. No problems with functions on the control pad.
What's happening is poor response from the temperature control and I'm trying to determine if it's the little temperature sensing thermistor or something else.
I turn on the unit and let it run.. temp set point is as low as it will go~ 61°. It's 70 in the shop... compressor doesn't start. I finally hold it against my warm body... got it up to 85º and the thing finally starts.
Put sensor in air stream from evaporator and watch temp drop right on down to 37º.. but system isn't satisfied and compressor keeps running. I finally put it in a cup of snow and it drops down to 35º... and in about a minute it finally shuts off.
The temp display on the control pad is really responsive to
the temperature changes with the thermistor.
That makes it hard for me to determine if the thermistor would be bad.
I don't know how quickly the electronic controls for the unit should respond.
I found a replacement board out of a working unit for sale on ebay for $50. Finding repair parts for these import window units is difficult.
What is your thoughts on the possibility that the sensor is faulty and causing this problem.... or would it be the logic in the controls circuit board not seeing the input from that sensor?
If the thermistor is giving a reading at all, does that mean it's good.. or could it give the right reading, but the logic to turn the compressor on or off isn't getting through?
