I recreationally pull this old farm tractor at this time in the 3500 lb. class. Rpm limits are in place that I can run 10 percent over 1815 rpm. But I’ve seen some groups allow 20 percent ( ive not participated ).
Background is in the press world of deep drawing metal for lamp bases. An old engineer (technical advisor told us at lunch one day ,that the only difference between his bandes 100 ton press and the 120 press was the bigger mass of the flywheel. Oh ! I stored that information in my memory for future use.
Now seems like a time to put this to the test with the Farmall 113 cubic inch .
I’ve pull a few times ,and I’ve been beaten pretty good. Some tractor in that weight class are sporting 200 cubic inch at much lower rpm . ( more toque ) I don’t lose tractor traction ,my engine dies out .
My theory is to make a steel flywheel that will be larger diameter
With more mass to improve the C113 torque at 2000 rpm .
Is my theory realistically worth the effort ?
If it is please tell what steel to use?
It would be a cup shaped flywheel about no more than 1 to 1 1/2 large diameter than the stock 9 inch clutch flywheel.
