Oddball Bridgeport clone (Hartford) spindle
Page 1 of 2 12 LastLast
Results 1 to 20 of 24
    Nov 2020
    9
    6
    Default Oddball Bridgeport clone (Hartford) spindle
    I just got a Hartford vertical mill. I took a chance on it from HGR in Ohio, it showed up the other day and for what I paid for it everything looks great. The only issue I have is the spindle bore is not R8, Erickson qc 30, or nmtb 30. It is an 1 1/4 straight bore about 2 inches deep with one set screw in the side. Has anyone seen this or know what it is? There is no hole in the splined shaft for a draw bolt
    Jul 2004
    N. GA- 33.992N , -83.72W usa
    4,070
    112
    976
    sounds worse than a 1-A toolmaster. is the thing ancient ? as in pre-historic?
    maybe you can adapt a collet chuck. tg-100 or er40 . is this a turret bpt type
    machine- or more of a van-norman weirdo-turkey? a set-screw implies there
    will be significant runout to the spindle.
    are you sure this isn't some fucked-up production factory machine ,made to produce one part
    all day long with the same tool and slave labor?
    show a photo.
  3. Likes Homebrewblob liked this post
    Nov 2020
    9
    6
    It is a mill on a funky shop made table. I'm not sure how to add pictures
    Dec 2010
    Sydney Au
    630
    126
    119
    The Hartford here, which was bought new in the late 70s/early 80s(??)is R8. Due to replace bearings in the near future too, can't imagine what's done there on yours....sounds like a case of butchery or parts missing.
    If you "go advanced" to preview your post, "manage attachments" will appear below the dialogue box > upload pics > voila!
  6. Likes wgadelman liked this post
  7. #5
    Nov 2020
    9
    6
    This is the only picture I have till I get back home in a week and a half. It's looking up into the spindle.
  8. #6
    Jul 2004
    4,070
    112
    976
    if you really want a discussion, that photo is useless. we can wait for a better
    one.
  9. #7
    Mar 2005
    Indiana
    6,174
    2167
    2154
    The picture can be improved a little, but still not real easy to interpret. Need more angles showing other views. It doesn't have drive keys, so obviously not a 30 taper. Are you positively sure it's not an adapter inserted into the actual spindle taper?
  10. #8
    Dec 2010
    Sydney Au
    630
    126
    119
    Here's a potato spec pic looking up the spout of a 2S, taper should be sufficiently evident, it's probably closer to 4~5" deep, drawbar up the top of course.
    If it's 1.25", suggests it's intended to be R8, rather than anything else. Hard to imagine how you'd tighten a set screw, short of drilling the quill and doesn't strike me likely to produce much precision.
  11. #9
    Apr 2020
    Ohio
    1,343
    1153
    493
    Is this that shop made steel plate table with the hartford head?
    If so that’s not a vertical mill, more like a shop made drill press using a clone head.
    The head is fixed and doesn’t move right?
    And there’s no x/y table at all.
    Or do you got something else?
    Edit, never mind.
    Here’s what I thought you bought LMAO
    Used Drill Press Base | HGR Industrial Surplus
  12. #10
    Nov 2020
    9
    6
    Some better pictures
    Attached Thumbnails Attached Thumbnails kimg0151.jpg   kimg0158.jpg   kimg0153.jpg   kimg0152.jpg   kimg0154.jpg
  13. #11
    Dec 2004
    San Antonio, Texas
    234
    42
    270
    Frankenmill...
  14. Likes chewietwo liked this post
  15. #12
    Mar 2011
    Geneva Illinois USA
    6,565
    2943
    2634
    That is a machine designed to do one job. The only thing I can see that has any value is the bridgeport head and that is not not much as it appears that the original spindle has been replaced with a shop made spindle. Heaven knows what else has been done to the head. All I see is Bridgeport parts head and a few pennies of scrap steel.
    Tom
  16. Likes chewietwo liked this post
  17. #13
    Mar 2005
    Indiana
    6,174
    2167
    2154
    Yep, that's an odd one. Not sure what you'd even call that... A mill press maybe?
    Did they make a Beaver quick change in 1¼" diameter maybe?
  18. #14
    Apr 2020
    Ohio
    1,343
    1153
    493
    That’s wild. Is it possible there’s a tool inserted into the spindle? I’ve never messed with a bp so I can’t tel where the spindle ends and a possible tool begins.
    I agree ekretz, mill press
    What was your plans when buying this? I don’t see any hand wheel x/y movements, only locks.
  19. Likes wgadelman liked this post
  20. #15
    Nov 2020
    9
    6
    I bought it just for the head. I have a horizontal mill that I'm going to put the vertical head on so I can have both capabilities.
  21. #16
    Jun 2008
    VA
    809
    211
    326
    Should be easy to pull the spindle, take the setscrew out of the back and unscrew the nose. A new spindle can be found used pretty easily. If there is a thru hole for a drawbar you could probably loctite a sleeve in it for a more common taper.
  22. Likes wgadelman liked this post
  23. #17
    Nov 2020
    9
    6
    There is no through hole for a draw bar. I did a quick check on eBay the other day and didn't find a used R8 spindle. Was looking at the new imports that come with bearings, they would work till I could find a used one no more than I'm going to use it for now.
  24. #18
    Nov 2020
    9
    6
    Yes. There is no drawbar through hole in the spindle
  25. #19
    Sep 2009
    Phoenix,AZ
    2,072
    3288
    561
    Do not count on BP parts fitting that Hartford head!! BP's are made to inch dimensions 99% of the imports were made to metric. I have worked on a few of the imports and the parts look very close until you try to install them. A idea is get a straight shank ER collet chuck that has the correct size shank and fit that to the spindle ER 25 would probably work out OK.
  26. #20
    Feb 2014
    Nevada
    9
    I also have a Hartford Milling machine head. I bought it years ago with the same thing in mind.
    However mine has a R8 spindle. When I rebuilt it I used Bridgeport parts. They were an exact match.
  27. Likes wgadelman liked this post
