partsproduction
Titanium
- Aug 22, 2011
- Oregon coast
After another expensive breakdown I decided to make a pathway for the operator to grease the rollers that a ring gear rotates on to drive the live tools.
Oddly there was no provision for grease or oil to the rollers, and eventually coolant turned the original grease into hardened mud, which not only caused the ring gear to seize but also rusted both the inner surface (Raceway) of the ring gear and the rollers and the inner raceway.
We ground the ID of the ring gear with a tool post grinder and sent the inner race to a hard chrome shop to grind past the rust, build up with chrome, and then grind to finish size. The rollers all went into a vibratory tumbler until the surface rust was gone.
I called the USA tech center for this machine and they knew of no method to grease or oil the roller raceway. Amazing!
So I drilled a long .089" diameter hole down from the outside of the turret base and ended up near the center of a 6MM flange that holds the rollers from walking out sideways, and then cross drilled a communication hole to the roller area.
I assumed the 115 rollers (6MM diameter X 8MM length) were lubed with grease so at the operator end of the longer hole I tapped it for a 1/8" grease zerk.
But when we assembled the whole thing with lubriplate it seemed like there was a lot of grease friction, which wasn't there when it was all dry inside.
So now we have a grease zerk that wants oil. Is it possible to inject oil through a zerk? If so, does it take a special injector oiler? Where can I get one?
Alternatively, is it possible to find a 1/8 NPT fitting with a female cone and ball that would work better?
Any thoughts on this will be highly appreciated, the operator is instructed to oil it every day. My thinking is that the coolant will be forced out by daily oiling.
parts
parts
