Is it ok to dissolve rust preventative oil on ER collets with WD-40 before use?
Results 1 to 13 of 13
    Nov 2019
    Massachusetts
    Default Is it ok to dissolve rust preventative oil on ER collets with WD-40 before use?
    Hey, so I just learned that WD-40 isn't actually a lubricant. Instead of using isopropyl alcohol/kerosene to degrease my stored collets for use, is it ok to use WD-40 and just spray the inside bore with a little air? or will this actually increase the likelyhood of a tool pulling out?
    Sep 2014
    Georgia
    544
    7
    91
    I use as for that purpose. I just wipe them with wd40 to prevent rust and clean. Was doing 90ipm 7000rpm .625 doc full woc with a 3flute carbide in 6061 aluminum. I thought is was some pretty decent cuts. (That’s what happens when you set your offsets wrong) and no tool pull out. In an er32 collet.
    Most my tools are in er16 or 32 and while I’ve broken lots of tools I have yet to have one pull out. Just torque it correctly and it will be fine.
    Wd40 is like a solvent. Works great for cleaning.
  3. Likes FrodoLoggins liked this post
    Jul 2006
    Hillsboro, New Hampshire
    7,829
    1827
    5505
    Try to avoid breathing in airborne WD-40, it's not great for your lungs. But I use it for collet and toolholder cleaning when changing out tools, just make sure they're blown or wiped off well to avoid leaving a heavy coating behind. I like to twist the tool in the collet before tightening to help wipe off remaining WD.
  5. Likes FrodoLoggins liked this post
  6. #4
    Feb 2007
    Aberdeen, UK
    3,654
    1261
    1423
    I used to use WD-40 heavily for cleaning just about everything like this. These days I use it very rarely for anything at all.
    I use two products for collet systems. Clean everything with flushing solvent, fast evaporating no residue, everything meaning holder, collet, collet nut, and tool. Then I spray aerosol silicon oil inside the nut and in the collet seat and on the threads of the holder. No oil on the collet or the tool. This means that every interface is lubricated except between the collet and tool, which has no oil at all.
    I have two rules for collets in the shop that everyone follows - assembling them this way, and never using the collapse range of the collet except for drills. This way holders and collets stay in good condition and we haven't had a tool move in a collet in several years.
  7. Likes FrodoLoggins, cyanidekid liked this post
  8. #5
    Nov 2019
    Massachusetts
    Hey you mean like an HVAC flushing solvent? Are there any you'd recommend?
  9. #6
    Jun 2016
    New York
    1,618
    928
    727
    I rarely use that crap for anything, its a waste product, neither a lubricant nor a solvent, cleverly marketed to sell.
  10. Likes TheOldCar liked this post
  11. #7
    Feb 2007
    Aberdeen, UK
    3,654
    1261
    1423
    Quote Originally Posted by FrodoLoggins View Post
    Specifically I use Ambersil FE10, dispensed into a Wurth solvent capable spray bottle.
    Then I use this silicon oil, also from Ambersil.
  12. Likes FrodoLoggins liked this post
  13. #8
    Mar 2009
    5,222
    97
    971
    Quote Originally Posted by cyanidekid View Post
    Last night I used a little on some scrap wood to start a fire in my Buck stove.
    Can't wait until my gallon can is empty.
  14. #9
    Jun 2012
    Idaho
    3,153
    1734
    2052
    I use LPS 2,,,love it
  15. #10
    Feb 2004
    peekskill, NY
    24,506
    4598
    ..., is it ok to use WD-40 and just spray the inside bore with a little air? ...
    Yes, WD-40 is basically stoddard solvent.
  16. #11
    Nov 2019
    Massachusetts
    Much appreciated, you've been very helpful.
  17. #12
    Jan 2007
    Norfolk, UK
    19,020
    14526
    14620
  18. #13
    Dec 2008
    New York
    10,234
    2656
    many rust preventatives are a spray of mineral spirits and asphalt tar which gives in general a non sticky wax like coating. usually dont want any or not much oil in a rust preventive cause it sticks to fingers when touched
    some (better than WD40) sprays are actually mineral spirits, mineral oil and asphalt tar giving a oily coating that eventually dries with a extremely thin wax like coating for rust prevention and lubrication. obviously mineral spirits will help again dissolve asphalt tar that has dried
    paraffin wax often used instead of asphalt tar. its often considered a dry or drier type lubricant compared to oil
    petroleum jelly usually doesnt dry. its a sticky lubricant. sense it doesnt dry its messy if applied all over stuff as a rust preventative. and if warm or hot storage conditions its more likely to melt or drip off
    grease which is soap and oil eventually dries as oil drips and evaporates. dried grease can act like a glue at times
