As the title says, I've got two lathes. An old 17" Clausing and a 90's new to me Kingston HJ1700. Using an Iscar SGTBU side hung blade holder on a CA sized Quick Change tool post, the Clausing will smoothly part stuff off 10" away from the chuck. Take the same tool and material out of the Clausing, and put it in a CXA on the Kingston, and it chatters no matter how close to the chuck I get, or what speed I try. The only way I can get it to work is by running the tool .060 low from center. The Kingston appears to be in excellent shape, and the chuck jaws seem to grip well all the way to the nose. I put a dial indicator between the tool post and material, and I can get about .001 deflection by prying under the chuck and against the tool post, etc. I could really use some suggestions as to what else to check?
