One More Time - Caliper Recommendations
Page 1 of 4 123 ... LastLast
Results 1 to 20 of 74
    Mar 2006
    Wisconsin
    1,185
    14
    420
    Default One More Time - Caliper Recommendations
    As per the title I am looking for advice as to which caliper to purchase. I've done a search, but the newest thread on the subject is at least a couple years old. I currently have Starrett 120 6", a Mitutoyo 505-689 6", and a handful of unmentionables.
    Both the Starrett and the Mitutoyo have been damaged over time. The Starrett has apparently been dropped and the gear at the back of the dial is missing a tooth, and the Mit looks like someone got it too close to an end mill in that one of the measuring anvils has a nick. I can still use the Mit If I position the work properly, but it's beginning to be a PITA. The Starrett on the other hand is DOA. I've contacted both manufacturers, and they say both can be repaired. However the cost to repair is only slightly less than the price of new ones.
    I like both, but would say the Mit has a slightly better feel. I'd like to get another of the same model, but so far all the vendors I've contacted say they are out of stock, even though their websites say differently. As for the Starrett even though there is currently a model 120 in the lineup it's considerably different than the one I currently have.
    The other consideration is a digital. All the unmentionables are digital, and do seem accurate. Keep in mind none are used for final measurements. I always use the micrometers for final measurements. I do like the fact that they can change from Imperial to metric with the push of a button. The possible downside is battery life. My current ones seem to last a couple years at minimum. However I've heard complaints on this board about various brands that tend to "eat batteries". I'm not sure what the expectations are, but if they do last at least a couple years I'm OK with that.
    I don't need some of the features available on some digitals, like communication with a CAD system, machine, or DRO. I'm looking for a quality stand alone tool.
    Thanks in advance.
    Jun 2012
    Michigan
    11,639
    3977
    4142
    I think a shop hard on tools should buy a $35-$40 digital caliper and toss them often.
    https://www.amazon.com/iGaging-ABSOL...s%2C322&sr=8-8
    https://www.amazon.com/Fowler-54-101...656552&sr=8-10
  3. Likes bryan_machine liked this post
    Mar 2001
    Switzerland
    2,582
    2563
    1147
    Mitutoyo digital is easily the best bang for the buck. Batteries last forever, and they are scarily accurate. I have some that are about 18 years old now, still measure bang on on gages.
    If you want "best", then it's more a matter of aesthetics and feel. I know guys who swear by Tesa, but I prefer Mit. There are also details like thumbwheel, coolant proof, output.
    But you can't go wrong with Mit. Buy from a real vendor, the fakes are getting hard to spot.
    As for vernier, I have an Etalon that's almost magic both in feel and accuracy. I do use them too- figure why not while my eyes hold up, and it keeps me out of the woods when doing open tolerance work.
  5. Likes Jashley73, Trueturning liked this post
  6. #4
    Feb 2014
    FL
    3,433
    11703
    3934
    Mitutoyo digimatic coolant proof. One and done.
    I've had my caliper and mic for 8 years, since I started at this shop and they were assigned to me. I think I've replaced the battery in each twice, or at the worst, 3 times.
  7. #5
    Jun 2012
    Michigan
    11,639
    3977
    4142
    Don't think I would trade me Brown $ Sharpe for another brand..
  8. #6
    Mar 2006
    Wisconsin
    1,185
    14
    420
    Quote Originally Posted by michiganbuck View Post
    I think a shop hard on tools should buy a $35 digital caliper and toss them often.
    Both the damaged calipers are in the 40 year old range. Both were used in the shop where I worked. Unfortunately that's where both got damaged. It's possible I knocked the Starrett of a mill and it got damaged when hitting the floor. At the time it was my go to caliper, and was used on a daily basis. I stopped using it and just put it in the drawer when I started getting erratic readings. It's been setting there for years, and I finally decided to take a look at it. At first I thought it might be just dirty, but on closer inspection found the damage.
    I'm not sure how the Mitutoyo got damaged, I know for certain I didn't do it, but at the time I didn't have a problem with loaning out tools. I fear in this case my ignorance cost me. Now that I'm the only person in my shop, and lending is a no no I haven't had to replace any tools due to damage or loss. A few have been replaced due to the fact that they've just plain worn out, or are so obsolete it doesn't make sense to use them.
    I would expect a quality new tool would last at least as long as I would be interested in using it. Even if it only lasts half as long as the ones I currently have I'm guessing it will be functional long after I'm not.
  9. #7
    Feb 2016
    Washington
    210
    472
    113
    Quote Originally Posted by TeachMePlease View Post
    I have the same ones and they are amazing. Way better feel than the basic black and yellow Mitutoyos that lots of people have, plus the automatic on/off is nice. If mine broke today I would go buy the exact same pair.
  10. #8
    1,793
    103
    73
    Stand by for the master of all he surveys.
  11. Likes cmccull166, Limy Sami liked this post
  12. #9
    Nov 2014
    Florida
    4,511
    1731
    2163
  13. Likes gustafson liked this post
  14. #10
    Feb 2018
    255
    52
    47
    Quote Originally Posted by Screwmachine View Post
    As far as I can tell they don't makes fakes of the coolant proof models. I bought a used 500-672 off of ebay for that reason.
  15. #11
    Feb 2007
    Aberdeen, UK
    3,904
    1384
    1585
    Count me as one of the Tesa fans.
    I used Mitutoyo digitals for years until a group of us got Tesa calipers as freebies on a metrology course. I'd be hard pushed to go back to Mitutoyo.
    I have some other very good quality ones from Sylvac and Mahr also, but the Tesa just feels the best, and has nice big digits on the screen.
    Regarding battery life, all the good brands have exceptionally good battery life - one thing that trips people up frequently is mistakenly thinking that SR44 and LR44 batteries are the same thing, they are often sold as such so it's a forgiveable mistake. However, instruments that are designed for SR44 batteries (most of them are) will have very poor battery life if LR44 batteries are used instead.
  16. Likes fusker liked this post
  17. #12
    Jun 2012
    Michigan
    5,196
    4770
    3146
    Quote Originally Posted by projectnut View Post
    I'll never buy anything other than Starrett for my 12" calipers.
    They do have different variations on the 120 model. They new style is godawful, but they still have the old style. The dial ring seems to be the only visible change from what I can see.
    Here are all of the 6" models, maybe you overlooked some of them?
    Dial Calipers
  18. #13
    Jun 2012
    Michigan
    5,196
    4770
    3146
    Yeah those are nice too. Never owned a pair, but a coworker had a pair back in the day.
  19. #14
    Apr 2004
    Modesto, CA USA
    7,465
    1309
    I actually bought a cheap harbor Freight digital for my nephew. They are rated as being accurate and he is not using anything else so the repeatability is really all that matters to him. I took all six on the shelf out of the boxes and only two felt smooth in the hand. One of those felt better then the other so I bought just that one. I would have bought a second one for myself but they were too stiff/jerky for me.
    I did later buy a Mit 8" at a pawnshop and it feels more balanced then the 6" to me with my big hands. I think a 4" would also.
    Bil lD
    Bill D
  20. #15
    Jan 2007
    Norfolk, UK
    19,859
    15301
    15576
    Whatever Gordons knocking out cheap this week.
  21. Likes MichaelP, camscan, Trueturning liked this post
  22. #16
    Sep 2002
    People's Republic
    4,451
    432
    2706
    +1 on the Tesa, or I am fond of the B&S relabeled ones with the black orange face
    Brown & Sharpe 599-579-5 Dial Caliper; 0-6" Range-Black Dial
    dunno who these are, but they aint Amazon, don't think they need more links
  23. #17
    May 2010
    DENMARK
    3,721
    4080
    12731
    Quote Originally Posted by Limy Sami View Post
    Were you nicer when drunk?
    I only sell calipers when a customer asks for them. It's up to the customer what make of digital caliper they want.
    Find a cheap caliper on my website.
    Home
  24. Likes Trueturning liked this post
  25. #18
    Jan 2007
    Norfolk, UK
    19,859
    15301
    15576
    IIRC it was you who appointed me as head of marketing.
  26. Likes fusker liked this post
  27. #19
    Feb 2014
    FL
    3,433
    11703
    3934
    So you're a barker?
    I always knew you were barking...
  28. Likes Limy Sami liked this post
  29. #20
    Oct 2007
    SPAIN
    3,938
    2296
    1549
    I'm assuming the Godron can peddle his website so much nowadays because he paid The Don for the metrology big job...
    Ref calipers...
    I was an original Tesa guy for a lot of years for Inspection.
    And had Mittys for general shop use which were strong/good feel.
    I bought 4 of the newer Tesas (big screen made in China half the price of the Mitty) and initially liked them.
    They had the big screen which was nice and they were light.
    Being clumsy when i swung round with them in my hand and knocked them, or dropped them in the machine or the floor...mr clumsy... and the internal blades would dent.
    They're not as robust as the Mittys by a long shot in my clumsy experience....
  30. Likes Trueturning liked this post
