LegendLength
- Sep 18, 2018
I'm trying to understand the best way to fit a one way bearing (i.e. sprag clutch) to a 12 mm shaft. The sprag is CSK 12 ( CSK & CSK2RS Sprag Type Freewheel | Combined Bearing Freewheels | Sprag Type Freewheel | Stieber Clutch ). They say:
Using an online calculator it gives me a shaft diameter between 12.023 and 12.012 mm . Is it as simple as getting the shaft within that size range then pressing it on with a cheap hydraulic press?
And can I be confident the bearing won't slip under the rated torque (around 10 Nm from memory)?
They do have a keyway version but i'd like to stick to non-keyway if possible. Especially because I also have to put a sprocket on the outside.
Edit: Actually I'd like to use a keyway for the internal and press fit for the housing (sprocket). So please swap all that around above thanks.
If units of standard clearance (C5) are used, the inner race should be fitted to a shaft of n6 tolerance, with the outer housing to N6 tolerance.
