O'ring groove design
Page 1 of 2 12 LastLast
Results 1 to 20 of 26
    Mar 2021
    CANADA
    Quebec
    10
    5
    Default O'ring groove design
    Hi all,
    I was wonder how to design O'ring groove and how to know the requirements for rod sealing. I need to seal 1.125 in stainless shaft in a welded stainless bushing against water pressure (150psi). The rod will slowly rotate by hand, so no heat build up. I don't know where to start.
    Regards
    Philippe
    Nov 2018
    Michigan
    700
    379
    456
    Quote Originally Posted by phelop View Post
    Hi all,
    Regards
    Philippe
    https://www.parker.com/Literature/O-...ORD%205700.pdf
    Start with chapter 5, section 27 (page 123) or section 28 (page 125).
    Jan 2005
    CANADA
    Saskatchewan
    10,313
    1410
    3761
    Hi all,
    Regards
    Philippe
    O-rings need lubrication, so they are not ideal for a rotating condition because the inside surface will wear out. So look for a lip seal style ring. Usually for low pressure, they will spec a softer durometer grade of rubber.
    Mar 2021
    CANADA
    Quebec
    10
    5
    It will be rotating by hand like quarter of a turn a time.
    Apr 2008
    Helmer, Indiana, USA
    1,283
    353
    557
    For a one off, non-flight critical I'd use a 2-022 o-ring. The groove in the shaft would be 1.125"-0.140"+0.008"= 0.993" and make it 0.078" wide. The bore would be 1.125" and the shaft would be 1.120". You can flip the numbers if you want the groove in the bore. The groove in the bore is lightly more of a pain in the butt.
    Edit: Said 2-024 meant 2-022.
    Mar 2005
    Kansas
    8,511
    586
    4258
    Hi all,
    Sounds like a recipe for a seized up shaft and bushing. The two need to be dissimilar materials.
  7. Likes Limy Sami, AlfaGTA, tdmidget, Dualkit liked this post
    Sep 2010
    Oklahoma City, OK
    5,412
    1040
    2351
    Quote Originally Posted by HuFlungDung View Post
    Parker details allowable rotation in their handbook. It's not much, but it's not 0 either.
    If I recall correctly, I just emailed them asking for a copy and they sent me one free of charge. That was a couple years ago.
  9. #8
    Nov 2018
    Michigan
    700
    379
    456
    Quote Originally Posted by gbent View Post
    Ha, just noticed that we have some stainless-on-stainless action here.
    Parker book says not to, but in a case like this you might be able to get away with using the o-rings as guides to keep the shaft out of contact with the sleeve. If your shaft is 1.1250.003" you should bore the sleeve to 1.1340.003" and groove two grooves to 1.3430.003" spacing them as far apart as you reasonably can. Then jam a pair of -219s in there, you want the ID size larger than the shaft to seat the OD of the seal against the groove so they will stay put on assembly.
    Stainless and water sounds like it might be a potable/food system. Get FDA EPDM o-rings and don't use lube if that is the case. Otherwise use standard grade EPDM and use a silicone grease, it will last longer. 70 durometer should be fine.
    That's what I'd do anyway.
    Edit to add:
    Quote Originally Posted by Kyle Smith View Post
    For a one off, non-flight critical I'd use a 2-024 o-ring. The groove in the shaft would be 1.125"-0.140"+0.008"= 0.993" and make it 0.078" wide. The bore would be 1.125" and the shaft would be 1.120". You can flip the numbers if you want the groove in the bore. The groove in the bore is lightly more of a pain in the butt.
    I'd recommend not using an -024 for the reasons I stated above. That o-ring will stretch around the shaft which is unideal for the application. You want the ring in compression, so it should be sized up in diameter. Additionally, the stainless seizing concern lends itself to a wider gap and two-ring approach as long as hand-twisting is the only load on the shaft which is much more forgiving with the larger cross-section of the -219.
    One more thought: Grooving the bore is the correct way to do a rotary seal. Only groove the shaft if you have no other way to get the job done.
  10. Likes phelop liked this post
  11. #9
    Apr 2008
    1,283
    353
    557
    Quote Originally Posted by BoxcarPete View Post
    Edit to add:
    Fat fingered the 2-024, meant 2-022, which is under compression. I'm not sure I'd classify this as a rotary seal. Why is a bore groove the only correct way?
  12. #10
    Nov 2018
    Michigan
    700
    379
    456
    Fat fingered the 2-024, meant 2-022. I'm not sure I'd classify this as a rotary seal. Why is a bore groove the only correct way?
    Fair enough, -024 has ID of 1.114" so with a shaft of 1.125" it would work in a bore-grooved design but -025 would be better, and a deeper groove with a -219 would be better yet! And as I mentioned before grooving the shaft is undesirable due to the black magic nature of seal design. You wouldn't think it matters much but the force balance ends up causing the o-ring to grip the shaft or slipping between the two, leading to "weird stuff" happening.
  13. #11
    Apr 2008
    1,283
    353
    557
    My experience is primarily in 850psi (paintball) applications, but I haven't seen any difference between a grooved shaft or a grooved bore. I preferred the former if possible as it was easier to make and measure. I agree o-rings do odd things sometimes. I'm not clear on why a -025 with an I.D. of 1.176 would be better.
  14. #12
    Nov 2018
    Michigan
    700
    379
    456
    Is that a reciprocating or a rotating seal? For reciprocating it doesn't much matter, the downside to grooving the shaft is that it becomes a "piston" and needs to ride in a bore at least as long as the stroke. For rotational configurations, if it is on the rod it should be stretched or it won't assemble correctly. If it is stretched, heat from friction will cause it to expand but also weirdly contract, like a boa constrictor taking a deep breath while squeezing the life from you. That's why "weird stuff" starts to happen, it is gripping the shaft and also expanding into the groove and pushing against the OD. In this case it probably doesn't matter much since it's just hand-operated, but using the seals as a bushing will work better if they are grooved into the bore as well.
    The reason 1.176" ID is better than 1.114" is for the pre-assembly condition. Every o-ring needs to be biased one way or the other in its pre-assembled state (i.e. assembled to one mating component but not the other). Most commonly, a seal is stretched into a groove, this is the "piston" configuration so it is easy to get into the habit of spec'ing a 1~4% stretch on all o-rings. However, in the "rod" configuration the o-ring is installed into a groove and its OD needs to be seated against the groove, so it needs to want to be larger than the shaft size. It's hard to reconcile specifying a seal which is larger than the shaft and also supposed to interfere with it, but don't worry, once it fills the groove it's got nowhere else to go, and it'll squeeze the shaft.
  15. #13
    Mar 2021
    CANADA
    Quebec
    10
    5
    I need to make the groove ont the bushing not the shaft !
  16. #14
    Jan 2007
    Norfolk, UK
    21,199
    16572
    17253
    As has been said already, stainless on stainless will soon become a single part.
  17. Likes toolsteel, Dualkit liked this post
  18. #15
    Apr 2008
    1,283
    353
    557
    Reciprocating.
  19. #16
    Nov 2012
    Wisconsin
    2,310
    3803
    2856
    I am by no means a o-ring guru.
    Where I work we rarely run into the need to machine o-rings. A few years back I received a print for a part from one of the imagineers here. He had basically designed his own o-ring groove that needed to be milled into a part. (apparently the one in question for this post will be turned). I looked in the Harvey tool catalog for a cutter. Found out Harvey makes tools for Parker spec o-rings.....after a brief conversation all o-rings here conform to the Parker spec and we use the Harvey tools.
  20. #17
    Nov 2018
    Michigan
    700
    379
    456
    Quote Originally Posted by toolsteel View Post
    Makes sense to me. Only minor correction I have is that AS568 is the spec, and was not written by Parker (ISO-3601 is a metric translation of AS568 for size and contains additional surface finish and flash controls). However, Parker wrote the book, and it is damn near the ONLY book, on o-ring design. For further reading, consult James Walker (no affiliation) for their o-ring guide. EVERYTHING else is a copypasta of the Parker book or one of its subsections. I find that kind of funny, as I was told in school that plagiarism would have consequences when I grew up.
  21. #18
    Nov 2004
    Webster Groves, MO
    7,987
    2077
    3902
    Whether the O ring is on the shaft or in the bore can make all the difference. I learned that when I tried to use hydraulic cylinders to measure jet engine thrust. Readings were jerky and erratic. Since this was a small jet engine, a Turbomecha Marbore IIF, the forces were not that high so O ring seals should work fine. The problem was simple once I got my head on straight. When you are using hydraulic pressure to move the piston, the pressure is trying to move it forward and is also pushing the O ring on the piston in the direction of travel. When the piston moves, it tends to roll the O ring in the opposite direction and the drag on the O ring is mostly just the friction against the bore. If instead you try to use the cylinder as a pump, both forces try to push the O ring into the clearance between the piston and cylinder, much like the action in a sprague clutch. It isn't an accident that the O ring in your hydraulic jack's pump is in the bore, not on the piston.
    To decide where to put the rings requires defining exactly what you want to do.
    Bill
  22. Likes HuFlungDung liked this post
  23. #19
    Oct 2013
    st,louis mo
    747
    383
    25 years ago,I made a triple lifetime all stainless 125 foot hose reel.It has stainless on stainless gland.I used 3 oring grooves right next to each other. When you are cutting an oring groove,it only takes seconds to move your lathe carriage and make another.I filled the space between grooves with non toxic silicone grease. It hasn't seized up or leaked a drop in 25 years. Edwin Drnbeck
  24. #20
    Mar 2021
    CANADA
    Quebec
    10
    5
    Edit to add:
    Thanks, the shaft will be rotating by hand.
