jigman586
- Jan 25, 2013
- United States
Do any of you guys know what the OSHA regulation is for a piece of bar stock sticking out of the spindle on a lathe?
If there is nothing specific, OSHA always goes back to the "General" clause
"The OSHA general duty clause, Section 5(a)(1) of the Occupational Safety and Health Act, requires that each employer furnish to each of its employees a workplace that is free from recognized hazards that are causing or likely to cause death or serious physical harm."
JR
I assume this is sticking out the back end? Chances are it won’t be that long I would just put a saw horse to the side with a big red sign that says “Do not touch.” If it’s really hanging out there then some sort of support device should be in place which is rather self explanatory. If you don’t have a bar feeder or bar support then your material should only be sticking out a foot maybe two any more and your lathe would turn into a helicopter at any sort of rpm due to instability. I’ve seen it happen up close thankfully I had the sense to hit the deck. The operator claimed the bushings failed. There were no bushings ever installed.
Or something like this Lathe Bar Stock Accident - Whiping at high speed - YouTube
JR
This dipshit either lied on his application or needed to be made to take a piss/breathalyzer test.
You need to get out more. Even experienced operators and programmers make stupid mistakes. We had a programmer that forgot to remove a G96 command. No big deal except the part was 6" dia and 42" long. That big Doosan went up to 2,000 RPM before they could hit the E-stop. Not pretty.
JR
JR
The sign is only to serve as a warning not to prevent some dumbass from tripping into it lol
Hard to regulate against something like that. I doubt if any the MTB's even recommend any length of unsupported material stick out?
We put a max of like 100 RPM in the post processors so that the programmer had to manually change.
The safety manual that I wrote for this company stated that max unsupported length was 3D on anything 4" dia and larger.
There was a machine with a SMW steady rest, but it was "busy". That stunt cost about $45K to repair.
When a machine goes through a episode like that lucky it's not destroyed.
Destroyed a $30K ATS, 20" chuck. Both machine doors, and the control housing. ULM was really upset that none of these parts were on the shelf and that the machine would be down for 6-8 weeks.
JR
AIt's a good thing it didn't let go of it or you'd most likely have added the cost of a funeral to the tally.
That reminded me of a guy I used to work with who came from PSNS shipyard.It did come out. Right between the operator and the programmer. IIRC, 472 lbs. Only went another 20 feet after taking out the doors.
Notice
