OT, 230 Chrysler Ind. Engine Parts.
Results 1 to 6 of 6
    Jul 2009
    S.W. PA
    243
    64
    59
    Default OT, 230 Chrysler Ind. Engine Parts.
    Sir's,
    A good friend of mine has collected an old combine with a good running Chrysler 230 flathead 6 cylinder ind. engine and needs an exhaust manifold. This application has an updraft carb and exhausts out the top. These engines are still very common as they were placed into many welders, compressors, fork trucks etc. I would very much appreciate any leads to that end.
    Thanks for your consideration,
    Bob....not the cat.
    Dec 2012
    AUSTRALIA
    2,993
    12
    973
    if its the old WW2 one ,so called "Burma " Dodge engine ,he should have no trouble with spares made for the Power Wagon restorers.These motors are the 3 7/16 " bore engine......Incidentally ,its folklore if you run these engines with the thermostst removed ,the head will crack ..............PS ,for a manifold gasket ,use black silastic ,the cheap hardware store stuff.......very surprising how long it lasts in exhaust heat............I used a keep a fleet of flathead forklifts going with silastic ......very versatile stuff.
    Aug 2013
    stockton ca.
    40
    5
    32
    How far is your search, parts are everywhere. Im in california and have several sources. Off topic but the heads crack mostly from water tube rotten or left out, nothing to do with thermostat.
    Apr 2011
    Nebraska
    1,308
    1981
    414
  5. Likes Bobnotthecat liked this post
    Jul 2009
    S.W. PA
    243
    64
    59
    Thank you, Ron, for the great leads.
    They have given me some ideas.
    Bob....not the cat.
    Apr 2011
    Nebraska
    1,308
    1981
    414
    Glad to hear it Bob. Let us know how it works out, preferably with pictures.
    -Ron
