stephen thomas
- Jun 3, 2001
Neighbor collects old cars, mostly British sports type. Seems to be branching into "mid century" American iron....
He tends to get an idea, and then bring parts by for me to repair or modify. He's good for the dough. Problem is that his ideas are frequently quirky or incorrect. Not sure what car sites he may be getting info from. So it's usually best to do some research before attacking with the methods he is certain will fix things.
The pictures are of parts represented to be the steering column and shifter from a '51 Mercury.
His idea is that it won't shift, because the projections on the shifter tube (lower part in photo) are "worn" "rounded". It does not look that way to me. Other than maybe the left-most upper corner of the left-most projection.
He is adamant that all I should do is weld up all around both projections and mill them square and parallel. These projections are actually somewhat hardened, and pressed in from inside the tube and then spot welded. (induction welded) As far as I can examine, the holes they are pressed through are the same shape as the current configuration.
Anyone able to tell from the pictures if the projections are factory spec for all intents and purposes, or if they indeed are worn too much?
The forks/conrod shaped items have some slight wear on the tops where the keys on the column enter, But it does not look like it would be enough to cause problems. Or is it? Anyone here conversant with these things?
smt
smt
