OT- "Air Bag needs service" message on 2010 Chevy Express
Page 1 of 2 12 LastLast
Results 1 to 20 of 36
    Dec 2000
    Coastal Dogpatch, SC, USA
    51,443
    2907
    5742
    Default OT- "Air Bag needs service" message on 2010 Chevy Express
    1. Don't see any codes related to airbag sensors on my Bosch OBD II reader....do I need a more sophisticated reader ?
    2. As I understand it, most likely culprit is sensor(s) either in front of vehicle, under seats or coil in steering column.... any thoughts of which is more likely ? Or will a proper OBD reader indicate where the problem lies ?
    Aug 2010
    Minnesota
    2,056
    160
    1519
    Just take it to a shop, total nightmare. If you want me to go into details I will... but man they are a pita.
  3. Likes Pathogen liked this post
    Dec 2000
    51,443
    2907
    5742
    Quote Originally Posted by kustomizingkid View Post
    ?? Seems simple enough if problem is a sensor...
    https://m.youtube.com/watch?v=16Ek8YfxYt0
    Sep 2002
    People's Republic
    4,383
    419
    2670
    you need to be able to read the body control module, most cheap scanners do not
    Aug 2010
    Minnesota
    2,056
    160
    1519
    Quote Originally Posted by Milacron View Post
    I would say in my experience its a 70/30 split of just a sensor vs wiring issues. To clarify 30% component failure and 70% wiring. Now I live in the frozen salt crusted north so you may not have the same experience.
  7. Likes Milacron liked this post
  8. #6
    Aug 2006
    Virginia
    617
    875
    357
    I found many front impact sensors in my experience as a GM tech. I couldn’t recommend replacing the sensor/s without a definitive code read. The trucks sensor failures outnumbered any other fault 20 to 1
    for what it’s worth. Those sensors are easy to service too. Use care when manipulating the connectors.
    Joe
  9. Likes kustomizingkid liked this post
  10. #7
    Nov 2013
    Eastern Massachusetts, USA
    5,302
    5090
    5117
    Which model is your Bosch?
    This comparison chart shows what each model is supposed to be capable of.
    | Bosch Diagnostics
    Also, is the firmware up to date? If not you can download the latest firmware for models that are internet updateable.
  11. #8
    Dec 2000
    51,443
    2907
    5742
    Quote Originally Posted by Scottl View Post
    | Bosch Diagnostics
    1150.... looks like I should have got the 1200 (purchased about a year ago).
  12. #9
    Jan 2007
    Norfolk, UK
    19,613
    15059
    15223
    "Air Bag needs service" message on 2010 Chevy Express ''
    There must be dozens of old mother in law jokes in that statement
  13. Likes Scottl, camscan, Zahnrad Kopf liked this post
  14. #10
    Dec 2000
    51,443
    2907
    5742
    Quote Originally Posted by Joe Rogers View Post
    Joe
    i found the impact sensor... center under radiator.. is tha the only one on a Chevy van ? Unlocked the connector, pushed in and out a few times in case of terminal corrosion... made no difference...
  15. #11
    Dec 2007
    Central Ohio USA
    3,939
    91
    1766
    I have a Tech 2 (factory Chevy service device). In it, and the factory service manuals, it mentions that often, 'proprietary' faults won't self-clear without 10-20 consecutive starts without the fault. So if your scanner can't get to it natively, you may have to wait several starts to see if you fixed the problem.
  16. Likes Scottl liked this post
  17. #12
    Oct 2005
    17,261
    IIRC that's where the van came from.....
  18. #13
    Jul 2009
    Peoria, IL
    11,738
    51
    9003
    Hmm. Isn’t the air bag module under the drivers seat? I don’t know who thought that was smart. Especially in a work van.
  19. #14
    Jul 2014
    Ontario, Canada
    1,038
    745
    677
    Obligatory “everyone is a moron except me” comments aside, it’s the front sensors, wiring or steering wheel clock spring as noted above that are the usual suspects.
    Same issue on the Silverado/Sierras. New front crash sensor fixed my Duramax.
  20. #15
    Aug 2006
    Virginia
    617
    875
    357
    If it is a sensor circuit code then my experience is the sensors fail. Usually a small crack in the housing and moisture probably. Not a wiring problem unless accident damage causes a harness failure.
    Did you get the code pulled? GM SIR sensor codes can detect a failed sensor or high or low resistance. The first step is getting the code from the module to prevent spending $ without a resolution.
    Joe
  21. #16
    Dec 2000
    51,443
    2907
    5742
    No code yet.... today I ordered a $125 "never head of brand but has good reviews" reader from Amazon that reads and resets SRS codes so will be a few days... If wondering why I don't take it to AutoZone for a free read... license plate expired and no insurance on the vehicle now as I don't use it... so obviously not legal to drive on highway to get to wherever.....fixing details so I can sell it.
  22. Likes Joe Rogers liked this post
  23. #17
    Dec 2007
    Central Ohio USA
    3,939
    91
    1766
    According to this chucklehead:
    YouTube
    This device:
    https://www.amazon.com/gp/product/B0...581a71802343af
    Will interface to the Tech2 computer software offering (which you'd have to source) when running on a (older 32-bit only) computer. Don't know how much that is, or where to get it. But I do think some level of it is available 'by the day' or 'by the week' or something.
    The nice thing about Tech2 is that it can directly access most sensors, re-set them if applicable, and even toggle operation of software-controlled switches. Example: I can 'push' the dash button for 4-wheel steering, make the 4WS dash lights cycle independently of the switch position, and make the rear wheels steer (while parked). So pretty much total control. Haven't played with airbags, though...
  24. #18
    Jul 2007
    UNITED KINGDOM
    4,995
    2821
    2452
    Quote Originally Posted by Chip Chester View Post
    Do you need someone to hold your beer?
  25. Likes Limy Sami, Joe Rogers, TeachMePlease liked this post
  26. #19
    Dec 2007
    Central Ohio USA
    3,939
    91
    1766
    Don't drink it, but thanks anyway.
    Plus, this thing has quite a few cupholders...
    Really want those airbags to stay tucked away, for some reason.
    I have had to dive into both the QS system and the electrically-adjusted shocks on the truck. The factory manuals are built around having Tech 2 access, and they do guide you right to the problem. However, they don't guide you to the parts -- poor availability for the more unusual ones.
  27. #20
    Mar 2005
    Kansas
    7,813
    473
    3708
    Quote Originally Posted by Limy Sami View Post
    And the proper name for the indicator is MIL. (Malfunction Indicator Lamp). Its there to nag you, just like it's namesake.
