OT: Aircraft Sparkplug Socket Suggestion
Results 1 to 19 of 19
    Sep 2004
    south SF Bay area, California
    2,021
    155
    651
    Default OT: Aircraft Sparkplug Socket Suggestion
    I need a 3/8 inch square drive sparkplug socket to fit aircraft sparkplugs with 7/8 inch hexes. A number of aircraft mechanics have warned me away from several different socket brands that they have been disappointed by, but none have been willing to recommend a best-overall socket . . . Except for one guy who swears by a WWII-era Plomb socket that was passed down by his grandfather. FWIW, the Plomb socket is 3 1/4 inch long and has a 3/4 inch square external hex that allows it to be driven by an open-end wrench.
    Thanks in advance.
    Nov 2007
    marysville ohio
    9,472
    2726
    6309
    Quote Originally Posted by John Garner View Post
    Thanks in advance.
    Get a 7/8 x 3/8 deep socket, part it off and weld the correct size tube between the socket parts. Job done, it's not rocket science you know.
  3. Likes Garwood, steve-l liked this post
    Oct 2009
    Oregon
    4,452
    4791
    2308
    Quote Originally Posted by moonlight machine View Post
    Get a 7/8 x 3/8 deep socket, part it off and weld the correct size between the socket parts. Job done, it's not rocket science you know.
    I used to build transmissions, mostly sticks for pickups, racing and medium duty stuff. I have a vidmar drawer 6" deep and 60" wide filled with sockets I've made like that. Some of them I made the entire thing from scratch, but most were just the end of a socket welded to a tube and another socket welded to the other end.
    It can look real good if you put a tiny bit of effort into it.
    Apr 2010
    Justin, Texas
    349
    100
    I bit the bullet and bought the Snap On one, S6106K, probably 35 years ago. At $35+ per plug, too much of risk to use something cheap.
    Jun 2012
    Eastern PA
    987
    275
    448
    What's a "3/4 inch square external hex"?
  7. Likes tdmidget liked this post
  8. #6
    Sep 2004
    2,021
    155
    651
    Um, an oxymoron? The Plomb socket has an external square rather than the external hex that's on the majority of sparkplug sockets.
  9. Likes awander liked this post
  10. #7
    Jun 2012
    Eastern PA
    987
    275
    448
    Here's one of those Plomb sockets for a little over $20 including shipping:
    PRATT & WHITNEY SOCKET, DEEP, 3/8" DRIVE, 7/8" 6PT, PWA 2254, PLVMB, SKU 12456 | eBay
  11. #8
    Apr 2004
    Modesto, CA USA
    7,080
    1194
    Then you shove a short piece of rubber tube or hose down into the socket to grab the terminal of the plug so it does not fall off and get lost.
    Bill D
  12. #9
    Feb 2010
    IN, USA
    228
    7
    250
    Quote Originally Posted by awander View Post
    The pictures don't show, but I assume it also has an internal hex for a ratchet. Otherwise it'd be a pain in the ass to use it with a torque wrench when reinstalling the plugs.
  13. #10
    Nov 2007
    marysville ohio
    9,472
    2726
    6309
    Quote Originally Posted by Punkinhead View Post
    The internal hex is for the spark plug, the internal square is where the ratchet goes.
  14. Likes awander liked this post
  15. #11
    Apr 2010
    Justin, Texas
    349
    100
    Quote Originally Posted by Bill D View Post
    Bill D
    LOL....no room...7/8's wrench flats with the upper plug body being about 11/16's.
    S-88 SPARK PLUG - Univair Aircraft Corporation
  16. Likes digger doug liked this post
  17. #12
    Oct 2005
    16,112
    Quote Originally Posted by cvairwerks View Post
    Yup, and if it was a problem, I could see a small knurled knob on top
    to rotate a nut to engage the HT lead threads, to "catch" the plug.
  18. #13
    Mar 2019
    ALAND ISLANDS
    32
    22
    12
    Not a professional A&P/IA.
    Iíve used both the ATS and Champion magnetic spark plug sockets for 30 years of aircraft ownership and maintenance. Iíve never dropped a plug that was the fault of the tool. Iíd be curious why your contacts have such difficulty in a recommendation for you.
    Example:
    ATS MAGNETIC SPARK PLUG SOCKET from Aircraft Tool Supply
  19. Likes DrHook liked this post
  20. #14
    Sep 2004
    2,021
    155
    651
    gbflyer --
    The socket-design shortcomings that I've been told about are 1) socket OD large enough to interfere with cooling fins on some cylinder heads, 2) socket ID too small to clear RF shield on some spark plugs, 3) socket opening too shallow to fully engage sparkplug hex on some spark plugs, and 4) socket drive recess has only one shallow retention dimple that doesn't hold the socket on the driver very well. I don't remember which is which, but these shortcomings are associated with sockets from Bonney, Champion, Cruz (sp?), and Giller.
    I had the single-shallow-dimple situation on a 1/2 inch drive Thorsen (which, I believe, stamped the Giller name on tools sold to the U S Government) aircraft sparkplug socket 40-some years ago. But my only use of that particular socket was in changing sparkplugs on a four-cylinder flathead engine, it was simple to hold the socket onto the ratchet.
    All that said, the ATS socket looks pretty good. Thanks for pointing me in that direction.
    John
  21. Likes gbflyer, DrHook liked this post
  22. #15
    Sep 2004
    2,021
    155
    651
    awander --
    Thanks for that tip. I may have a new old socket in my collection.
    John
  23. #16
    Mar 2019
    ALAND ISLANDS
    32
    22
    12
    gbflyer --
    John
    Thanks. Wow, Iíve been lucky I guess, but Iíve just never had any of that in terms of interference or not reaching the hex with Champ or ATS. Iíve never had an oddball engine though. Itís been C90, O290, O320, O470, IO520, and O540 experience for me. Might be an issue somewhere else.
    No problem on the link. Happy to help. Hope you find one that works for you.
  24. Likes DrHook liked this post
  25. #17
    Mar 2019
    ALAND ISLANDS
    32
    22
    12
    Polled a couple of other friends and the Snap On S6106K came up again.
  26. #18
    Jan 2012
    Midland, Texas
    1,501
    498
    765
    John
    Where did you find a four-cylinder flathead airplane engine?
    I've never had a problem with an ordinary 7/8" deep socket (Proto, Challenger, etc.) on Continentals & Lycomings.
    There are locking socket extensions that grip a socket better than the older extensions. You can get those at auto parts stores and Harbor Freight.
  27. #19
    Sep 2004
    2,021
    155
    651
    steve45 --
    The flathead four bangers were liquid-cooled ndustrial engines, not aircraft engines. Nevertheless their sparkplugs had 7/8 inch hexes.
    My aircraft sparkplug socket came from a discount store in 1974 or thereabouts. It was blister-packed as a Herbrand 1/2 inch drive deep socket, priced at $1.49 (IIRC).
    Interestingly, the socket I got was branded Thorsen, while some of the other hang-cards contained Bonney-branded sockets that appeared to be absolutely identical to the Thorsen-branded sockets.
    I suspect that Triangle Tool-- the owner of both Bonney and Herbrand brands -- was the actual manufacturer, making the aircraft sparkplug sockets as specials . . . Packaging and selling "overruns" under their economical Herbrand brand. I also suspect there may have been a government contract involved, because I saw visually-identical sockets marked as Bonney and Giller in Air Force civil-engineering "power production" tool boxes in the late 1970s.
    John
