Bill D
- Apr 1, 2004
- Modesto, CA USA
Off Topic? I bought a set of old solid brass Swedish angel chimes. Problem is the top bearing seems to be too stiff for them to work. They do run for a minute if push started. They have a brass rod with a taper at the top and a brass bearing cap tube that sits on top. I have read there may be a glass bead for a bearing that sits on the pin. I can not see anything in there.
I can see no wear. Is there any point in trying to polish the pin or anything. I do not think any lube would be thin enough to work. I always thought they run dry.
Bill D.
Bill D.
