Have heard there are inspection ports where a fiber scope might go but that's all I know. Also, do you use a monster wrench to turn the crank by hand to get each cylinder in optimum position for viewing ?
Would a straight bore scope work just as well as any or would one that flexes be of any benefit ? Look directly thru glass or LCD screen type ?
I can relate as I have one of those cheap LCD screen scopes like one buys at Home Depot and it is indeed a PITA to have to keep the LCD screen in proper orientation " to see what you need to see" in combination with the flex scope movements. Regardless, it has been quite useful in tight wiring runs on the boat, but I can see how a separate stationary monitor would be even better indeed.I don't know the answer but I offer a comment on video bore scopes in case you need to buy one to perform the inspection.
I much prefer the type where the display module is remote (connected by wire only) from the flex arm/camera. That way you can place the display in a fixed (hands free) position for easy viewing making it much more intuitive to manipulate the camera onto the desired area.
When the display is physically coupled to the flex arm/camera (display screen moving around while trying to orient the camera), I find it a real PITA except in the simplest uses.
Seems like mine is the "Rigid" brand, maybe 100 bucks on sale...which sounded dirt cheap at the time considering the pretty clear color screen and all. But it is a PITA sometimes as one basically is having to make two bends at once to see the little screen properly...one bend of the "camera" and then the opposite bend at the monitor to orient the screen back to optimal viewing.Glad to here yours was cheap. I think I spent over $300 for my Milwaukee POS to learn that lesson.
These days there are many better and less expensive options. Such as . . .
Amazon.com: Wireless Endoscope, Depstech WiFi Borescope Inspection Camera 2. Megapixels HD Snake Camera for Android and IOS Smartphone, iPhone, Samsung, Tablet - Black(3.5 Meter): Industrial & Scientific
Have you actually tried the one you link to ? Wondering if the image quality is similar to the image quality of the smartphone or tablet....i.e. does one have "retina screen" quality view of the bore if using a retina screen iPad for example ?
Plus there would be the advantage of keeping the images as a jpeg or video file in the device...for later viewing, image size increase, or email or whatever.
I found mine yesterday. On 1993 vintage Detroit 12V71TA, the inspection covers are held in place by two bolts..... except the two most forward cylinders on each side are one longer cover that covers two cylinders, held by three bolts ! No clue why they did it that way.There are six inspection doors per side on the outside of the block. They actually should look more like a small door that is held in place with one bolt.
Yesterday I saw on of the cylinder inspection holes for the first time, and now realize once the view end is inserted, I need to be able to see 360 degrees, up and down. Which means I need a "steerable head" type.....which I feared means big bucks.....but the below eBay one is surprisingly cheap. I wonder how easy it would be to "articulate" the head compared to the $8,000 types however....may start another thread just on articulating bore scopes.Glad to here yours was cheap. I think I spent over $300 for my Milwaukee POS to learn that lesson.
Yeah I thought about that a few hours after I posted the link. I'd prefer the straight one if it was shorter but come to think of it, the acessable inspection covers for the starboard engine are on the side between them and the hull, in which case the straight scope might be too long. But if they made one about 1/3 that long I would still be inclined to go with the straight one.. . . and the seller's in your neck of the woods.
I see that you linked to the scope with the rigid extension, not the flexible one.
Both have articulating tips but don't forget about the fixed focal length. You'll need to get the camera the correct distance from the subject, not just pointed at the subject. Will you have sufficient access clearance to achieve both focal distance and orientation with the rigid extension?
Yes, there seems to be 3 rings per cylinder. Re "bar the engine" I have turned them over before with a 3/4" ratchet on the 1.5" nuts on the front pulleys with a 2 foot extension and don't recall it being all that difficult. It would be nice to have a helper though just to shout "ok, stop" when piston at bottom.Those borescopes are really trick but I've inspected many a Detroit without one. Anything good or bad can be seen through the ports in the liner. You'll also want to look at the rings as they pass by the ports, it's handy to have a strong youngster along to bar the engine for you. Also would be a good time to go through the tune up. Don't forget to look for excessive oil in the cylinders at bottom dead center. If the engine has oil ring problems it can get expensive.
Notice
