OT: Automotive ground strap question
Page 1 of 2 12 LastLast
Results 1 to 20 of 34
    Jul 2004
    central NC
    2,680
    43
    731
    Default OT: Automotive ground strap question
    Doing some preventative maintenance on a 2001 GMC Yukon. So the braided ground strap from the firewall to the engine looks pretty "green" and I'm going to replace it since apparently a bad ground can cause all kinds of hard to solve electrical issues. My question is: why is the strap braided and not a nice insulated piece of stranded cable?
    Thanks.
    May 2011
    New Jersey
    3,357
    373
    1910
    The braids supports higher amperages, greater heat dissipation, and dependable performance when there's linear movement, lateral motion, or repeated vibrations.
    Jan 2005
    Houston
    7,233
    1369
    4236
    There is no point in having a ground insulated.
    You can buy good quality braided ground straps for cheap, so for the average vehicle there's no benefit in reinventing the wheel.
  4. Likes reggie_obe liked this post
    Feb 2005
    9,807
    16822
    12017
    Quote Originally Posted by GregSY View Post
    Just to throw some fuel on the fire..
    how about "Coated" to prevent corrosion?
  6. Likes wheelieking71 liked this post
  7. #5
    Jul 2004
    central NC
    2,680
    43
    731
    Other than an insulated cable with properly sealed ends won't degrade over time until it starts causing hard to diagnose electrical problems! Just watched a video of a guy whose Chevy van would die periodically. The dealer replaced the ECU, no change. Then the fuel pump, no change. Finally the owner figured out it was the braided ground strap.
    Yes, it is a cheap part and will probably last longer than the vehicle will. While I'm at it I'm going to clean the connections on the other grounds and the battery terminals. I hate electrical problems.
  8. #6
    Jun 2001
    St Louis
    19,555
    2478
    3746
    They usually ARE coated. The silverish look is often from tin, which is resistant to many common corrosive materials, and is plated on the srands to resist corrosion.
  9. Likes Bobw, bhigdog liked this post
  10. #7
    May 2021
    Virginia
    303
    337
    70
    Quote Originally Posted by JST View Post
    I thought they were galvanized.
    Sent from my SAMSUNG-SM-G891A using Tapatalk
  11. #8
    Jun 2018
    New Mexico
    190
    262
    86
    Quote Originally Posted by 52 Ford View Post
    That one made me laugh. Are you a "standup comic" ?? :-)
    ...lewie...
  12. Likes JoeE., Just a Sparky, 52 Ford liked this post
  13. #9
    Mar 2011
    Geneva Illinois USA
    6,632
    2975
    2664
    Just for the record, galvanizing usually refers to dipping in molten zinc, which in this case, would have resulted in a rigid bar. People often refer to zinc plating as galvanizing which it is not. Zinc plating is done in electroplating tanks. JST is correct. Most copper that is coated is coated with tin.
    Braided copper cables are seldom used these days as it is not mechanically protected and cost more to make than insulated cable. It is better when there is a lot of vibration and flexing. A good automotive application would be bonding the engine to vehicle frame.
    Tom
  14. #10
    Aug 2010
    Minnesota
    2,217
    198
    1704
    Bonding the engine to the frame?
  15. #11
    Jul 2006
    Hillsboro, New Hampshire
    14,136
    3091
    9369
    Quote Originally Posted by kustomizingkid View Post
    Electrical definition - not a mechanical bond, but an assurance that there's uniform and sufficient electrical continuity between objects.
  16. #12
    Nov 2003
    6,068
    219
    2095
    Cable implies a grouping of multiple conductors, separated with insulation. Only a single conductor is needed for the ground strap so cable is overkill. The real question is braided strap vs. stranded WIRE.
    As far as I can see, the only real current that will flow between the engine block and the chassis is that needed for the generation of the sparks. This will be in pulses as each spark plug fires with rest periods between them. Perhaps heat is a concern, but I suspect that resistance is much more of one. Any resistance here would produce a Voltage drop from the 12V battery Voltage and that drop would cause a weaker spark unless the circuitry provides against that. But even that would have it's limits so a good, low resistance connection is needed and is probably the less expensive alternative.
    As for braided strap vs. stranded wire, both are used when motion and vibration would eventually cause a solid wire to fail due to metal fatigue from repeated flexing. And if the total cross section area of copper (or other conducting material) is the same, both braided and stranded should provide the same resistance. The choice of one over the other is likely due to more mundane issues, like the cost of terminating the ends. A piece of stranded wire would be round and would need some form of termination, probably crimped terminals on the wire ends or electrical screw style terminal blocks on the engine and frame. A piece of braided strap can have a hole drilled or punched in the end and a simple bolt and washer would then be used to fasten them to the block and the frame. A quick dip in a solder pot before creating that hole will prevent those ends from fraying. A self tapping screw with a drill tip would eliminate two more steps in the process for even greater economy. All of that can cost less than applying a crimped terminal or using terminal blocks. On top of that, crimped terminals or terminal blocks also add two more potential points of failure between the wire and the terminals. So the braided strap without terminals is more reliable.
    Since you are not Ford Motor Company or GMC or Toyota and do not have an army of bean counters looking over your shoulder, you can feel free to use the twisted, stranded wire with the appropriate terminals. I would apply some form of corrosion protection after fastening the ground wire in place. Properly installed, it should last just as long.
    Quote Originally Posted by SteveF View Post
    Thanks.
  17. #13
    Sep 2010
    Oklahoma City, OK
    5,650
    1094
    2474
    And not to be confused with grounding.
  18. #14
    Nov 2003
    6,068
    219
    2095
    If you are talking about grounding like in a house or building where there is an actual ground rod, no it is not a ground.
    Since a typical vehicle sits on four or more rubber tires, which are very good insulators, there is nothing in it that is actually grounded. Nor is there any need for that except at toll booths where the toll collectors do not want to be the path for static discharge. Ouch!
    The engines in most vehicles are mounted on (synthetic) rubber mounts and are electrically isolated from the frame/chassis. But the Ignition system is usually/often mounted on the engine due to the need to time the sparks to it's rotation. The battery usually has it's negative terminal connected directly to the frame/chassis so the return path for the 12 Volts that operates the ignition system must have a return path and that is provided by a wire or mesh strap connection to the frame where the battery negative is connected. It is easy to see how a bad connection between the engine and the frame could cause strange performance problems.
    So, yes it is an electrical connection, not a mechanical one. But I do not think it could be called a ground. "Common" or "battery negative" or "return path" would be better terms.
    Quote Originally Posted by Cole2534 View Post
  19. #15
    Sep 2017
    South Carolina
    1,333
    736
    736
    And all these years I thought it was all about keeping your speakers from crackling from static electricity.
  20. Likes wheelieking71 liked this post
  21. #16
    Mar 2017
    356
    167
    A tremendous amount of current flows when the starter & solenoid are operating. Corrosion at the ground strap connects increases the resistance and can cause a large enough voltage drop so that the solenoid cannot stay engaged.
  22. #17
    Aug 2006
    Virginia
    635
    1043
    368
    A high traffic GM shop should have caught the bad ground strap quickly. GM vans have a handful of known issues and the GS is one. Along with overheating connector terminals in the fuel pump circuit.
    Joe
  23. #18
    May 2020
    Minnesota
    536
    213
    226
    Insulation on wire won't stop it from oxidizing. Many an old demolished wire I've stripped to find it's entire length oxidized from end to end. You can't rightly seal a stranded wire against moisture ingress unless you completely immerse both ends in No-AlOx or equivalent. Even so it doesn't make a lick of difference for the wire itself. It's the connection that is vulnerable.
  24. Likes BT Fabrication liked this post
  25. #19
    Mar 2005
    Kansas
    8,726
    625
    4441
    Quote Originally Posted by Just a Sparky View Post
    Is No-AlOx suitable for copper wire?
  26. #20
    Jul 2004
    central NC
    2,680
    43
    731
    Quote Originally Posted by EPAIII View Post
    Cable implies a grouping of multiple conductors, separated with insulation. Only a single conductor is needed for the ground strap so cable is overkill. The real question is braided strap vs. stranded WIRE. ..............
    Well, when I install a battery in an automobile I attach battery cables and when I help someone get their car started I use jumper cables, each having one conductor. This here is America, so if you want to call them something else, go ahead.
    Insulation on wire won't stop it from oxidizing. Many an old demolished wire I've stripped to find it's entire length oxidized from end to end. ...........................
    Yes, I can see where insulation is so old and degraded that it no longer protects the copper from oxidation. I can also see on 15-20 year old vehicles where frickin' mice have gone around doing taste tests of the wiring insulation that the copper underneath looks fine and is FAR better than the braided ground strap which is so oxidized it's green.
