OK...house is 4 years old, Goodman central A/C.
Problem #1
The unit is cooling the house...but not well. The temp drop in the air at the outlet vent is only about 8 degrees F via thermometer.
The outside unit seems to be working properly. The fan is spinning and the compressor is pulling around 8 amps. The big copper pipe is not cold though... only 5-10 degrees colder than ambient. Usually it would be sweating and cold.
If I turn the AC off for a while then turn it back on, it will show an air temp drop of 15 degrees or more - but it quickly backs off and settles out at the 8 degree drop. It's like it is on its way to a 20+ degree drop then something tells it to back off before it can ever get there.
Problem #2
The drain line is another issue which I can't see how is related to the air temp drop....I verified the normal drain line is draining but the drip tray still shows water and the backup drain is also dripping a little. It's like both drains are sharing the duty. What is odd is that the corner of the coil cabinet, right by the normal drain, is leaking water, as if there is a fault in the internal drain pan that allows the water to leak out rather than going into the drain pipe.
Problem #3
Even though the normal drain (which drains into the bathroom sink P-trap below) is working, it looks like they plumbed it below the level of the P-trap. It's hard to take a good pic of this but in any case...the bottom of the drain line is below the P-trap. Shouldn't it be above the P-trap?
Problem #1
Problem #2
Problem #3
