solidworks4u
- Apr 23, 2011
- 19970 DE USA
I need to have an appreciation of the tooling and specifically the tooling and process in the vacuum cooling/sizing chamber area. I realize that this is a process that is much more complex than a conventional extrusion. I included links (pictures hopefully) to equipment that is either for sale or is part of a product advertisement brochure. In this one piece of equipment that's for sale it appears that the tooling from a job is still in position, it appears like several blocks that have a profile of the shape of the extrusion space down the length of the chamber and that each of these blocks have a way to control the vacuum individually (I'm guessing here) and that the entire chamber holds some degree of vacuum (not a high degree of vacuum) the extrusion and these blocks where water is sprayed upon or is submerged in water that circulates (has a chiller) to cool the extrusion so when it comes out of the chamber, there is a device that grips the extrusion to maintain a uniform stretch (for lack of a better term) in the extrusion. And that each end of the chamber there is some kind of combination of wiping and close fitting opening that is arranged in such a way to allow any water that would slip past one of these multiple stages built into each end of the chamber, possibly with a air knife, so on the way out to make sure the surface is completely dry, so a good grip could be made on the extrusion. Downstream from this would be the sliding cut off saw. All of this would be in a facility that has good humidity control year-round so that the product is consistent and uniform when it is extruded. There are parts of this that I don't know are correct and I'm making assumptions I reach out to the form members and hope that someone has experience or knowledge in the area. If there is an area of suggested reading or other source that I may use to help myself understand the process better I would be very thankful and appreciate any help that can be offered.
16' Conair Vacuum Tank Model MSBH1-16-9, New in 2007 | Plastic Machinery | Used Plastic Equipment | Used Plastics Machinery
Cooling Tanks for Plastics Processing | Conair
I would like to send out my most sincere thanks to all the sponsors, moderators and others that make this forum possible and truly interesting and enlightening place. Thanks in advance to anyone they can help me understand this process better.
