OT: Converting Onan genertor to CNG
Results 1 to 15 of 15
    Feb 2008
    Richmond, KY
    413
    36
    5
    Default OT: Converting Onan genertor to CNG
    I was hanging out with a buddy today because I've been briefly disabled from shoulder surgery--and he presented me with this question. He has a generator from a big 'ol motor home that he wants to convert from gasoline to run on natural gas. I have not looked at it that close, but I know it was new in 1987 and it is a two cylinder Onan--probably about the same engine as the 316 & 318 JD riding mowers had.
    Is there any easy way to convert a small engine like this to run on natural gas? I assume the carb will have to be replaced, but is there some generic replacement for small engines? We were wondering if a small carb from a forklift might work...of course that would more than likely be for propane and for two more cylinders, so it was just a thought.
    Is this project even worth considering?
    Jul 2006
    Indiana
    573
    300
    100
    Yes, it can be done. You might spend some time reading here:
    Onan Generators - SmokStak
  3. Likes gustafson liked this post
    Feb 2008
    Richmond, KY
    413
    36
    5
    Thank you, Jim! That site looks like the mother-load of info on onan generators. I knew somebody here would point me in the right direction.
    Nov 2007
    marysville ohio
    10,825
    3027
    7485
    Quote Originally Posted by Regal13 View Post
    I would not bother with natural gas. I doubt you can raise the compresion ratio enough to use NG without losing a lot of power.
    Jan 2010
    Rochester, NY
    233
    5
    11
    Nov 2005
    N E Florida
    1,995
    169
    The Onan CCK engines were designed to run on gas, NG and LP. Not sure about the newer engines.
    I needed an intake manifold for a Miller welder with a CCK 25 years ago and a friend gave me one he had laying around that had an LP carburetor on it. The manifold was from the 50's 0r 60's. I made an adapter for it and put a VW carburetor on it! It ran great.
    The Onans are tough engines IF you can keep oil in them and water out of the exhaust!
    Feb 2005
    North Olmsted, Ohio
    478
    113
    SmokStak is indeed where you want to read. I have a 6500 watt Onan running on natural gas, although mine already came with a tri-fuel carb. Many home made conversions have been done, and there are lots of photos on SmokStak.
    Many of the Onan carbs have the boss cast on the side of the main body where the factory would attach the ng feed. It just needs to be drilled through and a second location tapped for a holding screw for a feed tube.
    There is no difference in the carb for propane or ng use, the ng setup is actually easier as you do not need a first stage regulator, just a demand regulator. Demand regulators are readily avilable on eBay. If you are using CNG from your own tank, it would need a pre regulator also. A manual flow valve does the duty of the gas adjustment on the factory built tri-fuel carb.
    Dennis
  9. #8
    Feb 2008
    Richmond, KY
    413
    36
    5
    well, i almost forgot about starting this thread here after going to smokstak. Someone there already had a thread started on the exact same thing.
    I did look at the generator closer and it looks like a 6.5 NH
    It came from a 1987 pace arrow (i think)
    I also found a few of them on youtube that are the same generator.
    I think the primary purpose he wants to convert it to run on natural gas is so he can hook on to the city gas line--which always seems to work, even after the carnage of a nasty ice storm. Also, it will be cleaner and not leave the carb gummed up for lack of maintenance.
    I wondered about the oil, too, as running from a gas line, it will never run out of fuel. Did they have an automatic low oil shut off?
  10. #9
    Feb 2005
    North Olmsted, Ohio
    478
    113
    It should have an oil pressure cut off. It is a sensor/switch located on the block near the oil filter. A single wire runs up to the points box and grounds the ignition when oil pressure drops.
    One of my Onans ( a CCKA) is a factory built industrial version designed for extended running with no service. It has a 9 quart oil sump! They would run oil field pumps and other unattended operations where they would only be periodically checked. The Onan 1800 rpm engines will go 5,000 hours between routine maintenance and many have not needed a overhaul until 15,000 hours.
    My other engine is a 6.5 NH like the one you are working on.
    Dennis
  11. #10
    Apr 2020
    Ohio
    19
    The company I work for is having a Retirement (going-out-of-business) Sale after 38 years and liquidating their entire machine shop. Lots of SOLID equipment with plenty of life still left in them including this DUAL-FUEL (gasoline or natural gas) Onan Generator-3 Phase (Lot # 277); they don't make them like this anymore! Know anyone with a need or room to give them a second lease on life?
    ONAN 30 EK GENERATOR 30 KIL, 37.5KVA, SINGLE AND 3 PHASE, 7 DIFFERENT VOLTAGE SETTINGS, RUNS ON G
  12. #11
    Oct 2005
    22,785
    Quote Originally Posted by WranglerRouser View Post
    spammers eat shit and die here
    I'm sure the OP has fixed his problem qty (8) years ago.
    Every single post of your total (18) post count is the same spamming "we are going out of business"
    We don't need your junk spammer.
  13. #12
    Jun 2012
    Michigan
    14,394
    4902
    5205
    I just converter a 4-cylinder air cooled generator from NG to petrol fuel/gas. The carb lever was much the same and it was a simple change as everything fit even the hose to the air cleaner....engine runs great and I am thinking about having 110 and 220 outlets installed and perhaps a 3-phase buzz box.
    Originally it was back-up for a retirement home.
  14. #13
    Jul 2007
    Missoula Mt
    1,454
    62
    737
    Keep in mind on ng the kw will only be 60% of gasoline, and a lot harder to start cold...Phil
  15. #14
    Jul 2006
    Indiana
    573
    300
    100
    ^ 60%? Not so sure about that. I see my Onan, rated at 7.5 kW, and capable of 9 kW on gasoline put out full rated power on NG. In my experience, cold temps make virtually no difference in starting ability.
    YES - you'll get less power with NG than gasoline, but I'd not assert it's 60%...
  16. #15
    Apr 2004
    Modesto, CA USA
    8,958
    1776
    I believe the big rigs running on CNG have much higher compression to run more efficiently. A compression ratio similar to diesel. You will have to have some sort of positive shutoff valve in case the carb sticks open.
    Bil lD
