gustafson
- Sep 4, 2002
- People's Republic
I was so pleased with myself, I thought I had posted about this before but apparently not.
I wanted pulldown stairs in my garage for some light duty storage above. I hate the rickety spring loaded ones, and had vain hopes that having somewhat 'real' stairs would mean it would not always be me fetching stuff from above[hah]
I dislike spring action, as it would not do what i wanted without what I considered excessive complexity
SO it occurred to me that a properly placed counterweight should get me what I want: push up and stay up, pull down and stay down.
My first thought was mount the counterweight on a 45 degree up facing leg. When the stairs are down, the weight is over or ahead of the pivot and thus pushing down; steps up, it is working to keep them up.
Low pitch roof frustrated that. Only maybe 15 degrees available.
reinforced the rafters.
2]2x10 stringers, rabbeted on the radial arm saw[hah]
2]2x12x8 worth of steps
1]2x8x8 cut in half screwed and glued at the max angle available to avoid hitting the roof
Pivots on a 3/4 steel pin.
Built a plywood box hung on another pin to fill with concrete for the counterweight
Built a guard box hung from rafters under counterweight so that if anything failed that box of concrete would not fall on anyone's head
The thing that is amazing is how perfectly it works.
When down the stairs have perhaps a pound or two of downforce.
At knee height they are weightless[will balance motionless]
By head height they are moving upward
Then they fly upwards.
If they did not rub on the sistered rafters, due to sloppy workmanship, it would be perfect
I sometimes have to give them a nudge to overcome the friction to get them to sit up between the rafters and not interfere with the garage door.
A rope with a weight on the end sits almost on the floor less than a foot from the garage door, the garage door takes it up with it on the way up, but it is that long so it cannot fall in front of the door.
So I got through with this post and thought for sure I had a pic on my phone and don't so I will have to edit it later
Thought it might be of interest........
pic of bottom is it floating just off the ground.
