OT:Cuttin up an Anhydrous Ammonia tank............
Page 1 of 2 12 LastLast
Results 1 to 20 of 21
    Apr 2007
    Pillager, MN
    5,690
    1856
    5159
    Default OT:Cuttin up an Anhydrous Ammonia tank............
    Is there any worries on cutting up a decommissioned anhydrous ammonia tank? Any residual AA? Tank is empty and valves/plugs are pulled already. Basically I can have it for scrap, just want it for the heads and a ring or two for backyard fire rings.
    Jun 2008
    Dassel,MN,USA
    102
    14
    48
    AA is dangerous sh*t.
    Take advantage of it sucking up water. fill, then drain the tank with water first.
  3. Likes wheels17 liked this post
    Sep 2006
    SW Wisconsin
    470
    12
    109
    Quote Originally Posted by Karl_T View Post
    What he said. ^^^
    Another way is to flush it with lots of air, as in large compressor, while taking the first cut.
    Ed.
    Oct 2005
    14,344
    I cut an old gas tank with my plasma cutter....I filled it with water.
    After the first pierce, it kept cutting nicely as the water rushed out of the kerf
    right behind the torch.
    yes, the hose kept filling it the whole time.
    Dec 2012
    AUSTRALIA
    1,787
    8
    541
    yes ,fine spray of water washes it all away.....I used to work at a fridge plant used ammonia,they had an emergency compressor driven by a 6 cyl Ruston and Hornsby big as a bus.........when there was a ammonia leak over night or weekend,the cops would let you know.
    Jan 2007
    Norfolk, UK
    18,497
    14022
    14008
    Quote Originally Posted by john.k View Post
    (my italics)
    IME Ruston & Hornsby never built anything small, ……….even their small power engines were massive for what they were.
    IIRC A lot of Ruston Bucyrus cranes were fitted with R n H diesels, which seemed to run for ever.
    May 2017
    FINLAND
    1,598
    456
    736
    Quote Originally Posted by david n View Post
    Anhydrous ammonia is really volatile and any remains should turn to gas and vent off.
    If the tank is dry from inside and ventilated to atmosphere already its just a empty tank. If it is containing any water that could have dissolved ammonia left.
  9. #8
    Oct 2005
    14,344
    Quote Originally Posted by MattiJ View Post
    The concerns are:
    Upon cutting with thermal means, more of the chemical leaches out and becomes a new hazard (even after cleaning)
    The container is not "open" enough to allow an ignition of any residue to just "woof", small fire.
    It's the first cut that is the problem.
    If it's the ends your wanting to save, I would do the initial cut to remove
    the area of the valves in the center. making a cut about 18"-24" in dia.
    After this piece is cut out, the explosion hazard is much less.
  10. #9
    May 2017
    FINLAND
    1,598
    456
    736
    Anhydrous ammonia shouldn’t ”leach out” to any troubling degree so its different from old oil tank or such. If there is additional half inch layer of bitumen or tar its different case.
  11. #10
    Oct 2005
    14,344
    Tell you what.
    I'll give you the torch/plasma cutter and you walk up to an "empty" 1000 gallon tank, and start cutting on it.....
    And I'll go dial 9-1.....
  12. Likes GregSY liked this post
  13. #11
    May 2017
    FINLAND
    1,598
    456
    736
    Yeah, there might be other chemicals left in ”empty” tank with unknown history but not ammonia. Cutting cast iron water pipes is also unsafe if someone has filled them with old dynamite..
    Ammonia is not problem for torch cut if you manage to breath next to the ventilated tank... odor threshold is 10000 times lower than lower explosive limit.
  14. #12
    Oct 2005
    14,344
    You say all these things....How many tanks have you put a torch to ?
    I have cut:
    1. a 300 gallon skid tank that had contained gasoline
    2. a 25 gallon chevy truck fuel tank that was just emptied of gas.
    3. An acetylene tank (and then welded on it to)
    4. A couple of 55 gallons drums with motor oil residue still in them.
    You really, really need to stop filling the internet with dangerous practices
    that are gonna get someone killed.
  15. #13
    Dec 2012
    AUSTRALIA
    1,787
    8
    541
    The Ruston was originally direct air start,but the HP compressor packed it in,and we rigged up a Indian Chief motorbike to run its back wheel on the flywheel....started the Ruston ,easily......One time ,the bolts holding the flywheel sheared,and the flywheel took off like a 10 ton frisbee,dragging part of the compressor.Did a fair bit of damage......after that ,there was a concrete wall built beside the fly wheel.
  16. #14
    Jan 2007
    Flushing/Flint, Michigan
    7,505
    371
    6280
    Why,
    Even if safe at the price of a fire ring is it worth the cutting gas, time and effort?
    I get the hacker idea in spades and like but sometimes the effort is just not worth it.
    That said I've often gone down this road.
    Bob
  17. #15
    Nov 2004
    WI
    4,675
    437
    1067
    Some Perspective...
    Across the street from my shop last week there was some work going on...
    I looked over the see what was going on and it was like a Road Runner illusion. I couldn't focus my eyes on something.
    A 35,000 BBL gasoline tank (Huge! about 1,470,000 gallons ) had a hole cut into it, maybe ten feet square.
    So they could drive a skid steer into the tank and clean out the bottom, or whatever it is they were doing.
    They did not consult with me.
    When they were done, they slapped the section back into place, and welded it all back up, and looks like some primer on the weld joints.
    Just think about that..... A huge gasoline tank at a gasoline pipeline terminal, cut open, work done inside, and welded back up again.
    I am real sure they did not fill it with water first!
    But again, Don't Try This at Home.
  18. #16
    Jul 2013
    Indiana
    3,181
    4658
    1613
    Why,
    Bob
    I'm with Bob, seems like a big PITA for a fire ring. I'd go down to the local farm store and get one of those galvanized rings they have that's used for livestock.
    Brent
  19. #17
    Sep 2010
    Oklahoma City, OK
    4,104
    711
    1740
    Quote Originally Posted by 3t3d View Post
    Some Perspective...
    More than likely they used a monitor to make sure the atmosphere was sufficiently below LEL and that's not something most folks have at their disposal.
    Also, they could have flooded the tank with nitrogen prior to commencing work. 35k bbl is about 200,000 cubic feet, well within the volume of a single ln2 transport.
    As an aside- should anyone have to cut into a vessel of unknown presure or contents there is a (relatively) safe way to do it. Grab your side grinder and begin grinding a small spot into the wall, paying particular attention to the freshly gound steel. When the steel discolors from the heat of grinding STOP. Place a sharp punch or chosel in the center and give it a whack, it will pierce the steel revealing to you whether or not it's fully evacuated.
    Same method can also be used to create a large window, more grinding though.
  20. Likes digger doug liked this post
  21. #18
    Mar 2005
    Kansas
    7,391
    421
    3380
    You don't state the size of the tank, but it was about a 300 PSI pressure vessel. It will be heavy and may not be worth it even at scrap price.
    As for using a galvanized tank from the farm store, no, I would not use anything galvanized to make a fire ring.
  22. #19
    Oct 2005
    14,344
    My neighbor weld shop makes fire rings.
    plasma cuts side as one big 12-16" wide 1/4" plate about 10' long
    Has wildlife scenes.
    They roll them, about 3' dia., and then weld on a top, this part is round on the outside, hex shaped hole for the fire, with "your name here"
    plasma cut on it.*
    * they keep a brand new one painted gloss black (I sandblasted it for them) with "Your Name Here" plasma cut in the top, take it
    to the annual RMEF get together, sell raffle tickets with it.
    Winner gets a custom one with their name on it.
  23. #20
    Jan 2005
    Houston
    5,494
    470
    2338
    The jamokes near me make large vessels...it's common to see a 16 foot diameter, or larger, that's 30 or 40 feet long. They make smaller tanks, too.
    As part of their normal operations, they scrap tank ends fairly regularly. Either QC issues or they damaged them or whatever. So there's a pile of them sitting there. They came up with the idea of making fire rings out of them, like a million other people.
    The problem is...the place was taken over by the owner's sons who quickly decided they were bad-ass artists, country boys who knew a thing or two, and they would drive their lifted diesel F-250's and sell fire pits to the stupid city folk.
    The end result is....I asked how much for a scrapped, smaller tank end...maybe 6 feet or so. The old boy tells me, "Oh, a couple thousands dollars..." Keep in mind this was not a finished product, just the tank end bare and rusty.
