OT: Cutting tile , brick or concrete with a 7 1/4" circular saw?
Page 1 of 2 12 LastLast
Results 1 to 20 of 31
    Jan 2006
    Brookfield, Wisconsin
    3,936
    199
    329
    Default OT: Cutting tile , brick or concrete with a 7 1/4" circular saw?
    Standard corded circular saw, 7.25" . Milwaukee, Bosch, Porter-Cable,Makita etc...
    So is it ok to cut Tile, concrete or brick with it, with appropriate blade ofcourse?
    Dry cutting or wet cutting.
    Makita has a masonry and tile cutting circular saw of 4 3/8" , with a No Load speed of 12,000 or 13,000 rpm.
    Their 7 1/4" circular saw for wood is 5800 rpm. Is the Rpm on the Makita Tile saw just a function of it being a small diameter (4 3/8") saw blade and not necessarily because you need high Rpm for masonry and tile?
    So for concrete, masonry and tile, one needs high rpm? But angle grinders which are used for cutting these materials are low rpm, about 3500 rpm for a 14" blade on an angle grinder cut-off saw.
    Nov 2008
    Madera county california usa
    2,289
    20
    553
    Have used correct blade and it works but not tge best.
    What is the project?
    Mar 2011
    Kansas
    930
    109
    260
    We've got two of these Makita 5057KB 7 1/4" circular saws w/ dust collectors.
    http://www.amazon.com/Makita-5057KB-.../dp/B00004YODW
    I bought them initially for a project in a plant we were working in, we grooved with a 3/8" wide tuck point blade ~1/4" deep or so for 2,000ft. Worked great. I had two of them built out identical so if one died we could switch them out but never a need to. I've now got that saw cutting 2" deep with an .090" diamond blade through a 3.5" sq prestressed beam of ~10,000psi concrete with two prestress wires in one shot and hasn't had a problem yet.
    I think the dust collector works well, but I've never used it in its factory setup. The first one I made a new base to fit my saw guide tracks that had additional brushes to help control dust, and the second setup has it in a box with brushes where the beam passes through so all the dust is contained and sucked out through the saw. Our cheapo dust collector on that is a 5gal shop vac with a cyclone bucket before it.
    Dec 2008
    Vt USA
    6,688
    658
    2097
    I used the "double insulated" $50 Makita to cut all the soap stone when We did the kitchen counters. (30 lineal feet of counter plus a side board) I purchased the stone "rough" and cut to suit , including the back splashes.
    Everything was done wet with the stone slabs supported on a piece of "blue board" ridged foam insulation. With another family member holding the garden hose to flood the cut line, but not flood the saw, operations went smoothly.
    But, soapstone is easy...
    May 2005
    AZ
    2,296
    201
    769
    Take note of the difference in diameters you are mentioning; if you run the numbers, you'll find that the 14" and 4.375" blades are running something like 12,000 SFPM, while the 7.25" is a little slower, around 10,500 SFPM. I gave the RPMs a little decrease assuming loaded condition. Long story short, they are generally equivalent for the different diameters.
    I used a 7.25" Skilsaw with an abrasive masonry blade to slice up stucco for removal on existing construction when I added the shop onto the house. No requirement for nice cuts in that case, but it worked "OK". If you are doing fancy work, hand-held usage is the lesser choice. I definitely would NOT use a hand-held run-of-the-mill circular saw to do wet cutting. That could lead to some interesting sensations.
    May 2005
    AZ
    2,296
    201
    769
    CalG, you're more trusting of those saws than me :-)
    Apr 2012
    New Zealand
    599
    149
    151
    Depends what you are cutting and how much. A diamond blade cutting concrete has a shorter life if run dry and there is an optimal speed for cutting.
    The dust from anything you might cut with such a blade is seriously unhealthy and a wet saw works so much better that it is a no-brainer IMHO. The dust also builds up in the motor and although it may seem to have done no harm, the saw cannot cool properly and lets it's smoke out in protest- this is com experience.
    Makita also makes a 7 1/4" wet saw and Hitachi makes or made a 6" wet saw-get one if you have any real work for it.
    I'd rather have the Hitachi and have not managed to destroy mine yet.
    Jan 2006
    3,936
    199
    329
    Quote Originally Posted by rbent View Post
    Makita 5057KB 7-1/4-Inch Circular Saw with Dust Collector - Power Circular Saws - Amazon.com
    When you say "grooved" , do you mean like a Dado blade setup (only in your case it is 1 blade that is 3/8" thick) on a table saw that cuts a groove/slot/channel ?
    Jul 2013
    Detroit, MI
    146
    10
    97
    I've had good success cutting 1" thick slate slabs with a circular saw. Borrowed a toothless diamond wheel from a tile saw.
    Dry cut + respirator + box fan for visibility seemed better in that case, since it was hard to get enough water to truly flush the joint without also flushing the saw, and the toothless diamond blade wasn't clearing the mixture.
    Definitely use a clamped straight edge as guide and support both sides of the cut with polystyrene.
  10. Likes Big B, DentorP liked this post
  11. #10
    Apr 2004
    Modesto, CA USA
    6,321
    994
    I have the little harbor freight wet saw with diamond blade. I used it to cut back stucco. a easy task that it handled well except... Part of the cut was horizontal and tight room meant I had to run it motor down. I could see water dripping from the fan housing. Tripped the GFCI several times with that orientation.
    Bill D.
  12. #11
    Jan 2006
    3,936
    199
    329
    Quote Originally Posted by CalG View Post
    This one? It is 5 1/2" , and costs about $245.
    Makita 5005BA 5-1/2-Inch Circular Saw with Electric Brake - Power Circular Saws - Amazon.com
    Which one are you referring to?
  13. #12
    Virginia
    24,168
    7561
    7491
    Quote Originally Posted by Spud View Post
    $245?
    Well... if yah really have no other choice ... I've used up THREE El Cheapo Chinese angle grinders, not saws, cutting out about a hundred square feet of five-inch+ concrete wall over a period of several years in Hong Kong.
    The local cost is about HK$300. Or less. US$ 35 or so. The dust doesn't kill them any faster than it would kill a $300 one.
    The slotted 'turbo' style diamond-coated blades are about $9 - $12 US. They have half the life of the best ones available, so the math makes them much cheaper.
    Cordless, unfortunately, just doesn't have the balls.
    Cored-ED in a 240 VAC environment one dasn't run wet.
    Hence the sacrificial nature of the process and the use of cheap tools and small blades.
    For THIS job, only a bespoke concrete saw would last longer. In the US, I've rented 'em - 2-stroke motor powered, garden-hose water attachment, and they work a treat - six-inch concrete floor, or vertically cutting a neat doorway opening..
    However ... their blades alone cost a multiple of the whole collection I used-up in Hong Kong.
    CAVEAT: All this to cut not-quite 2" deep slots on a 2" to 4" grid, then break out the checkerboard of cubes with a hand-drilling hammer and a sort of wedge/punch, not quite a chisel. Shovel debris, repeat for another 'layer'.
    Also works for trimming wall and floor tile for small fill-in around pipes and such. Proper wet tile saw - as I have in the US - is tons better, of course, but they don't do walls, windows, or doorways, nor demolition/preparation phase work very well atall.
    Bill
  14. #13
    Jul 2005
    Chevy Chase, MD
    1,057
    76
    87
    One of the few reasons to buy a Harbor Fright tool: You're going to do something abusive to it.
    I bought a HF 9" angle grinder and a cheap 9" segmented diamond blade from amazon.com - like $25 cheap.
    It blasted through 2 tile-over-mortar bed bathroom demolitions and has cut all the brick/paver/slate I've needed to do for about 5 years.
    I do cheat and blow it out at the end of longer jobs, though.
    Prior I had a couple pawn shop circular saws w/ grit blades. They're pretty spectacular when they finally die, and are the only tools I've
    killed through abuse.
  15. Likes Greenwud liked this post
  16. #14
    Jan 2006
    3,936
    199
    329
    Quote Originally Posted by Motomoron View Post
    No Harbor freight in Sri Lanka but there are cheapo Chinese knockoff but they are still too much money for what they are , such that for 30-40% extra I get brand name tools. Anyways I am taking a bunch of tools with me when I head over in a few days. I got a new Bosch 9" angle grinder over there but it doesn't have a shroud/guard/base like a circular saw, so that's why I prefer using a circular saw since I can get far more accurate results .
    So ...
    If I am going to flush with water while cutting tile and or concrete and other masonry, how safe are double insulated circular saws? Keep in mind it will be a 110volt tool running off a step down transformer (NOT an isolated transformer) that converts the mains 220-240v to 110-120v.
  17. #15
    Virginia
    24,168
    7561
    7491
    Surely you aren't using an autotransfrmer or Variac for that great a drop? It probably IS an 'isolatION' (not 'isolatED') transformer as part of the deal.
    IF THEN it happens to have a centre-tap on the 110/120 V side.. and you are able to Earth that .. soundly .. each leg presented at the tool could be only 60 VAC above ground. And it is 'A' C so there is a shake-loose chance vs stick-and-fry DC.
    There is still, however, the upstream 240 VAC feed somewhere in the area, so I'd certainly use a long extension to get well away from that AND the transformer it enters, elevate, cover, and tape whatever wanted kept dry, and be damned careful with the water.
    BTW .. back to that hand-drilling hammer and wedge or chisel I use... certain amount of fly-rock. Eye-protection more than mandatory.
    But damned little dust.
    Bill
  18. #16
    Jun 2009
    Michigan, USA
    2,293
    3273
    1707
    I have an old bottom of the line Craftsman 7 1/4" circular saw that I bought for about $10 for the sole purpose of sacrificing it to a diamond blade. Now about ten years later and one dunking from a flood it just cut about 1" deep for about 6 feet last week. Just can't kill it. I think the blade was about $25 at the big box store.
    Big B
  19. #17
    Virginia
    24,168
    7561
    7491
    Don't be too sure of that. Angle grinders rely on YOU for guidance, but at least are MEANT to manage molten-hot and highly abrasive debris. Circular saws (other than those intended to cut masonary) generally are not.
    Slicing a straight edge to cut-in a doorway or window is not so easy, either, when the base of a saw designed to slide over relatively flat and smooth dimensioned lumber, synthetics, or plywood has to be dragged over rough masonry or even irregular brick or stone.
    Expect a "character building exercise" in the near term...
  20. Likes matt_isserstedt, Greenwud liked this post
  21. #18
    Jan 2006
    3,936
    199
    329
    Bill
    One of these; placed order last week. Should be here next week. It is an autotransformer ; it is specifically made to run American 110-120v tools on UK 220-240v mains. It is 3kv continuous rated. From my research Carroll & Meynell is a respected UK brand of portable job site tool transformers, and their products are Made in the UK.
    UK to US Supply Conversion, 3kVA - CM3000/A/US - UK to US Supply Conversion - Products
    Well yeah I would be using a proper filter cartridge dust mask this time around ; last time I did concrete cutting I just used a basic disposable cloth mask. This time I'll take with me 3M cartridge type mask . Ofcourse I will also use Googles also. Still that concrete dust make it seem like it is snowing heavily , only its grey snow. Such a bloody dust-bowl when I start cutting. That's why I wanna use wet cutting .
    Makita does make a little 4 3/8 wet cutting tile saw , the below one , but what is soo different (from a electrical safety standpoint) between it and the 7 1/4 " circular saws used for wood? Other than the: "special cover" & GFCI plug??? Any special electrical additions/modifications you notice in the specs or pdf manual?
    Makita USA - Tool Details - 4101RH
  22. #19
    Virginia
    24,168
    7561
    7491
    Spud?
    "Priorities", mate.
    Yer daft. OCD, even, on the tools and their 'infrastructure'.
    You'll jump through dozens of costly hoops to arrive in Sri Lanka a 'subject matter expert', buried in paid-invoices and paperwork, over-equipped with esoteric tools..... and have WAY too little knowledge of the most efficient and EFFECTIVE way to simply get the construction task DONE with minimal effort and harm.
    It's basic masonry and wood work. Not a rocketship.
    Bill
  23. Likes Philabuster, Greenwud liked this post
  24. #20
    Jan 2006
    3,936
    199
    329
    Spud?
    "Priorities', mate.
    Bill
    Yeah I do have OCD , and try for best practices and cringe at shoddy work. Might seem annoying at times but my sis always gets me to hang pictures, minor house renovation, cutting the lawn etc.. cause she says I do it nice while her husband just wants to get it done and isn't concerned with how it looks.
