OT: Dental crown gold or Zirconia
Page 1 of 2 12 LastLast
Results 1 to 20 of 26
    Apr 2004
    Modesto, CA USA
    7,167
    1222
    Default OT: Dental crown gold or Zirconia
    I need to have crown made for a tooth. I already have two made of gold. My dentist is pushing zirconia instead of gold. this is for a back molar so it will not show. I understand pure zirconia can be stronger then any other material used in dentistry. I wonder if it can chip or crack. This is not zirconia with a coating to make it look like tooth enamel. those coatings tend to chip off over time.
    The price difference is only $50 so I will probably stay with gold since it has a good track record. Most information is just manufacturers glowing reports. I do not think it has been around long enough to have a ten or twenty year track record.
    I am 60 years old so that may influence my choice since I would hope any crown should last my lifetime.
    Bill D.
    Jan 2005
    Houston
    5,874
    587
    2683
    My dentist tells me nothing is as good as gold. He said ' you won't find any dentist that tells you otherwise'. A lot of times he recommends the white materials for appearance. But in terms of performance, gold. That's why I am only getting gold from now on for any back teeth.
  3. Likes Pete Deal, Joe Miranda liked this post
    Mar 2018
    ALAND ISLANDS
    13
    23
    The selling point of the Zir. Crowns is they showed a guy driving one of their crowns into a post with a hammer, pulled it out then put it back on the tooth. As far as durability I have 4 of them and still am very impressed
    Apr 2004
    Modesto, CA USA
    7,167
    1222
    Reading a bit more they may be too hard. They will cause more wear on the opposed tooth then gold. They seem to be pushing them as better then porcelain for exposed teeth but no real mention of comparing them to gold.
    Jan 2005
    Houston
    5,874
    587
    2683
    Let's not forget the ladies are drawn to gold....
  7. Likes tdmidget liked this post
  8. #6
    Aug 2012
    California, Central Coast
    4,059
    2227
    1590
    Is cubic zirconia with a gold band around it an option?
  9. Likes digger doug liked this post
  10. #7
    Jul 2011
    Oregon
    466
    126
    264
    My wife is a dentist. She says gold is the way to go. Most dentists would choose it for their own back molars. It's soft against the other teeth, durable, and has the best marginal fit. Zirconia doesn't have a long-term track record, and is difficult to remove if it ever needs replacement. It is very hard but that doesn't mean it can't break if there is a flaw in the material. The lab bill is a lot cheaper for zirconia, which is a reason some dentists like it!
  11. #8
    Sep 2009
    Apex, NC
    1,515
    750
    Interestingly, I JUST had a conversation with a friend who is a top-notch prothsodontist about this (he plans procedures with surgeons, makes and installs the prostheses). He actually has a lab, machines and fires zirconia, gold all sorts of materials and complicated cases. He says that gold, overall, is the best material, because of a number of properties such as a bit of malleability, and it can be made thinner and more detailed so not as much prep work and removal is required on the teeth, finer detail, easier fitting etc. Zirconia may have some cosmetic advantages in certain cases. The zirconia must be polished after firing, and after any fitting of mating surfaces, if left unpolished, it will wear the opposing surfaces. My dentist said when I had a crown made about a year ago, that it's sort of a tossup, and that the cost delta was just a small adder for the precious metals; he said he had never seen a zirconia failure. However, the dentist isn't making the appliances, and the straight from the horse's mouth from the prothsodontist carries a lot of credibility.
  12. #9
    Nov 2015
    Oklahoma
    278
    63
    137
    Don't know about zirconia but I had a porcelain one fail after a few years. Went to gold and have had no problems for 15 years. My Mother had gold crowns that lasted over 50 years.
  13. Likes Joe Miranda liked this post
  14. #10
    Apr 2010
    Georgia
    27
    5
    10
    I have gold crowns and bridge installed in 1973. Still working everyday.
  15. Likes Joe Miranda liked this post
  16. #11
    Jul 2004
    Asheville NC USA
    8,875
    3627
    3025
    Most of my molars have gold crowns. Several over 25 years old. Never have had to have any of them replaced, nor have I had any other sort of problems with them, with one minor exception. About a year ago, one came loose. Went to the dentist the next day, and according to his records he put it on in 1992. He checked the underlying tooth and the crown, cleaned both up to remove any remaining glue, and reinstalled it. Good as new. Based on my experience with them, I'll stick with gold.
  17. Likes Joe Miranda liked this post
  18. #12
    Jan 2005
    Houston
    5,874
    587
    2683
    This pretty much settles the issue.
    Kiiara - Gold (Official Video) - YouTube
  19. #13
    Oct 2002
    Florida
    1,194
    131
    279
    The accuracy of fit of the crown, whatever material, is the most important thing in a lasting restoration. Most dentists seem to prefer what I think is called “slice” tooth preparation which tapers the restoration down to a fine edge. I feel that a carefully done preparation where the restoration meets the tooth in a square edge can be better sealed. I lost a tooth that had a slice crown that did not cover the soft tooth material completely, leaving the tooth subject to decay. I got a gold crown several years ago that a slice edge was away from the tooth a bit. The dentist was able to burnish the ductle gold crown to fit well against the tooth. With proper cement under the well fitted edge, that crown has held up well. Quality dental work is the answer. I envisioned interviewing my next dentist with a discussion of his crown and bridge work, with him showing me examples of his work. I did not do that when we moved to Florida a bit more than two years ago, but recommendations from others seem to have put me into an acceptable situation.
  20. #14
    Nov 2002
    St.Louis, Missouri, USA
    2,089
    125
    469
    My dentist didn't talk about the material as much as the importance of the fit of the crown. Seems all the suppliers are all going to machining them instead of using the impression for a mold and the fit is not as good? He said that the fit is the most important part for success, otherwise the patient winds up with sensitivity to hot and cold and they may loosen over time.
    Dan
  21. #15
    Jun 2001
    St Louis
    18,210
    1959
    3093
    Have had "non precious metal" crowns for some time, like 20 years, and they have been trouble free.
    Had two replaced due to problems not due to the crowns, and the new ones are a machined material, dilithium silicate. have not had them long enough to judge longevity.
    I think the goodness or badness has far more to do with the dentist than the crown material. Dr Rosen who did the originals was extremely good. Maybe the gold is regarded as good because it is soft enough to compensate for any small misalignments.
    Zirconia vs. lithium disilicate - Dental Economics
  22. #16
    Nov 2012
    Wisconsin
    2,109
    3465
    2651
    Gold...it looks cool
  23. #17
    Apr 2004
    Modesto, CA USA
    7,167
    1222
    I see mention of titanium crowns. Did the old Soviet union use stainless steel for crowns. like the guy in then James Bond movies?
    Bill D
  24. #18
    Mar 2014
    Michigan
    515
    96
    300
    I once found a gold crown in a small Kennedy chest I bought at an estate sale.
  25. #19
    Jul 2004
    Asheville NC USA
    8,875
    3627
    3025
    I ran a bar for a couple years back in the 70's. A girl who came in regularly was a dental assistant. She came in one night and showed us this ring she'd made from partially fused bits and pieces of salvaged gold crowns. It was a really unique looking ring, but this one guy who worked for me never could resist adding in some wiseass remark whatever the situation. He says Wow Sylvia, that's a really cool ring but I never knew you had Nazis in your family tree.
  26. #20
    Oct 2002
    Florida
    1,194
    131
    279
    Bill D,
    I spent some time in the Soviet Union on a technical service assignment about 50 years ago. I saw a lot of people with stainless steel grins, and was told that the utilitarian stainless steel crowns and bridges were the standard offering of the state health service. If a Soviet citizen wanted porcelain crowns, he had to pay extra for the fancy stuff.
