Hobby Shop
Stainless
- Mar 20, 2014
- Michigan
I bought a low hour engine from a salvaged tractor. Its been sitting outside under a tarp for years when I bought it. I pulled the injectors, spun the engine and #1 exhaust valve is sticking. There’s not a scratch or imperfection the length of the bores and I can still see all the crosshatching. I checked with telescope gauges and it showed .0005” of being perfect. I’ll check again with a bore gauge when the pistons come out.
It looks like some water got in there because there’s a little bit of rust at the top of #1 cylinder. All 3 cylinders look smooth or somewhat glazed. I also had to smack the 1/2” ratchet with my hand to get it to initially rotate but it didn’t take much to turn over.
Unless someone tells me differently, the plan is to put the block on the radial drill, run the Sunnen AN-100 hone through it with a 180-220 grit stone, clean everything up, put all new rings and reassemble. The engine is a 66hp turbo diesel with 4.400” bore.
Any and all help is always appreciated, I’ve rebuilt plenty of dirt bike engines over the years but this is is my first go at a diesel engine overhaul and I’d like to get it right.
Andy
Andy
