OT- Do catalyst hardeners work with standard oil based enamels ?
Results 1 to 11 of 11
    Dec 2000
    Coastal Dogpatch, SC, USA
    51,641
    3074
    5945
    Default OT- Do catalyst hardeners work with standard oil based enamels ?
    "work" as in speeding drying times and painted surface hardness ? An example of "standard oil based enamel" would be Sherwin Williams All Surface Enamel.
    Like this for example - https://www.tractorsupply.com/tsc/pr...CABEgLCZ_D_BwE
    Thinking in terms of machine tool paint that is not so hard as Awlgrip or Polane, but a little more scratch resistant than standard issue enamel....and can be applied with roller rather than spray.
  2. Likes machinistrrt liked this post
  3. #2
    Mar 2009
    Eureka, CA
    4,307
    995
    1702
    Yes they do.
    When thinning the enamel, don't use 'paint thinner', use a medium reducer such as Klean Strip painters solvent. For a extra nice finish, add a squirter full of Smoothie fish-eye eliminator.
    Stuart
  4. Likes Milacron, TFPace, gustafson liked this post
  5. #3
    Nov 2013
    Eastern Massachusetts, USA
    6,838
    5855
    6246
    As atomarc said, not as tough as dedicated two part paints but tougher than with no hardener. Also used for striping enamels that will be topped with two component clearcoat. A friend had a VERY expensive custom paint job on a bike fail because the striper didn't add catalyst. The clear peeled off in sheets over the striping.
  6. #4
    Mar 2006
    jacksonville,fl.
    1,466
    1426
    494
    I used to be a SW dealer back in the 70's when they came out with the hardner for enamels. It did have a different pn than the urethane hardners but don't remember what the difference was if any.
  7. #5
    Aug 2005
    Manchester, MD
    269
    39
    The catalyst you linked to is the one you want to use. I have used it with Rustoleum. You can reduce the rustoleum with acetone if needed. Be careful about breathing the vapors.
  8. #6
    Feb 2005
    Ohio
    1,230
    1541
    228
    I have also used the TSC Majik hardner (and Majik reducer) in Rustoleum with great success.
    Mike
  9. #7
    Apr 2004
    Modesto, CA USA
    8,424
    1594
    I was under the impression the tractor supply(majic) hardener did not make the paint any harder. It just speeded up the curing process so the paint got full hard in under one week.
    I use Coleman fuel to thin the tractor paint. It is mainly naptha
    Bill D
  10. #8
    Sep 2002
    People's Republic
    5,828
    701
    3646
    I knew auto paint places made a urethane enhancer, but assumed there was a bit more science to it. Glad this subject came up.
    I will say even a modest baking[leaving a small part under a incandescent lamp overnight] makes krylon etc hold up better.
  11. Likes Milacron liked this post
  12. #9
    Oct 2003
    Philadelphia, PA
    928
    100
    Do these catalyzed hardeners also increase the chemical resistance to solvent cleaners (like acetone, toluene, etc)?
  13. #10
    Aug 2006
    california
    263
    24
    RH, Can you delete some messages in your mailbox? I'd like to PM you about a gear question.
    claya
  14. #11
    Mar 2009
    Eureka, CA
    4,307
    995
    1702
    Quote Originally Posted by RH68 View Post
    I'm aware this is a dead thread, but just noticed this post and will say this, the hotter the reducer used, the less sheen you'll get out of the paint. You can use acetone or lacquer thinner for that matter, but as the reducer becomes 'hotter' the final sheen of the finished paint becomes more dull.
    Stuart
