See attached pic of lamp, purchased several years back from Home Depot. I have a few of these around, and find them very useful for close work where you need some decent light. 50W halogen bulb that is supplied through a hi-low-off switch and 12V transformer in the lamp base. One of them stopped working, and after some bumbling around with a meter and replacing the switch, found that the transformer was open. I did some unwrapping of the windings, and found what appears to be a thermal fuse, which seems to be open, so I assume it's the culprit, unless the whole transformer is shorted badly. Transformer seems to have continuity on both sides, though.
Anyone out there with guidance as to how to rate a replacement thermal fuse in this application? Markings on the component are gone/indecipherable.
