easier to add the connector itself ? In other words, have older spec Heidenhain scales with their presumably unique 9 pin round connectors where I need to adapt to the new 15 pin D sub standard (the DRO's have 15 pin D sub male connectors so obviously I need 15 pin female D sub connectors)
I already did one of these, where I used L-Com cable with molded in 15 pin connectors and soldered the L-Com wires to the Heidenhain wires*....complete with shrink tubing on each of those tiny wires and larger shrink tubing to encased the whole deal when finished. It worked....but was a PITA....especially having to do it at the machine rather than at the workbench.
Heidenhain sells 9 pin to 15 pin Dsub adapters but the price is insane... like $140 each....but in my first case I had no choice but to do it the way I did as idiot previous owner cut the original 9 pin connectors off the cord anyway....and they cut the cord so short I needed the L-Com cord to reach the DRO ! (why they did this I have no clue )
Bottom line is, can you buy 15 pin D sub female connectors where you press fit the tiny female recepticles to the end of the wires and then press the recepticles into the D sub connector with a special tool ? That would be the ideal... no soldering or shrink tubing needed for one thing.
And if you can buy such...where ? And what special tool is needed to push the recepticles into the D sub ? Casual glance at Newark Electronics and all I see are panel type 15 pin D subs or gender changers.
*and before anyone says it, yes, the wire color coding Heinhenhain cable to L-Com cable was completely different so that the pinouts matched...but I figured it out
