magneticanomaly
Titanium
- Mar 22, 2007
- On Elk Mountain, West Virginia, USA
My dad taught me electrical wiring. We used fish tapes often, re-wiring old houses, the flat spring wire type in a springy sheet-metal reel. Pulled the tape out between the lips and wound it back in the same way. Never a problem.
Years ago, after my dad was gone, I lent one of our tapes to a friend, who broke it, and bought me a slick new plastic-housing 200 ft Greenlee, model 430-20, very nearly like this one Greenlee 438-1 Steel Fish Tape 2 “x 1/8" Greenlee Textron | eBay
It is a pain to use. The tape inside tends to get a later layer under an earlier, and then I cannot pull it out. Recently I took it all apart, (BOOM, a huge tangle!) completely untangled and straightened the tape(took an hour), and tried to re-load it. When I just pushed it in with the handle, the tape all stacked near the outside diameter, and about half would not fit. So I pulled it all back out, and wound it in under tension......it wound in a single file like a phonograph record groove, , and again would not all fit. Eventually I got it all in by again winding under tension but poking the tape through the holes in the sides of the case as it wound so as to distribute it across the width of the drum..
What am I doing wrong? Is there a trick to using this style? Is there a problem with this model? I think maybe so, because in looking at 222 of them for sale on e-bay I saw not one exactly like mine. I e-mailed Greenlee Tech Supporrt with this question, and got
"Hello,
Try to do with the help of two person. One hold the reel and other hold the tap and do it slowly.
Thanks",
"Hello,
Thanks",
