Modelman
Titanium
- Sep 12, 2007
- Northern Illinois
Well, it's time to bite the bullet and get the oldest part of our building re-roofed. 1800 sq, feet, wood deck, 130 feet of brick parapet wall, and about a half dozen penetrations for vent stacks and the like. The current coating is the common asphalt built up roof, covered with gavel, and is at least 25 years old.
I'm not real familiar with flat roof systems, but was always under the impression that on a built up roof, they just swept the gravel to one side, added more layers of hot "tar" and paper, then redistributed the gravel. However, none of the roofers quoting the job want to do this; each wants to quote a membrane system, and I am totally unfamiliar with the pros and cons of each system, so I'm asking for any experiences, good or bad. Here are the three that have been quoted so far, in descending order of cost:
EPDM Rubber The "rubber roof." I understand this material has been in use for quite a number of years, and the sheet itself seems to last a long time. Most of the failures I see discussed on the web seem to be with the adhesive used in seaming.
APP Modified Bitumen The "torch-down" roof. Most failures seem to be related to torch technique during seaming.
TPO Thermoplastic polyolefin It's new. It's white. It's cheap, about 2/3 the money of the EPDM. It also doesn't have a very long track record.
Comments?
Dennis
Comments?
Dennis
