moonlight machine
- Nov 19, 2007
- marysville ohio
I'v been on the lookout for a Kohler Command Pro 25 for my big mower. There are not many good used ones around so when I see one advertised used, runs good for 350.00 I was all over it. It was about 100 miles away, that sucks but if it runs good..... So I call the guy about it, he says yep it runs good.... I say I want to hear it run for 5 minutes or so, warm it up, make sure it idles and revs up ok. He says fine, no problem. I call him a day later and he he had it running on carb cleaner, just give it a squirt every few seconds...... I say no, I want to hear it run on gas. I call a day later, does it run on gas, Yep, it runs good! So I drive down to get it. When I get there I have him start it, It fires right up but is clearly only running on 1 cylinder and is spewing engine oil out the exhaust. He says yep runs good! I pull the plug wire off the dead cylinder, no change in idle speed. Shut it off I said and pull the spark plug. The plug is dripping oil and the side electrode is smashed up inside the plug along side the center electrode, I put my finger over the plug hole and spin it over. No compression, I put a long screw driver in the plug Hole...No piston! Yep...Runs good!!! Who is the low price seller of Kohler engines?
