SAG 180
Titanium
- Sep 17, 2007
- Cairns, Qld, Australia
Been doing some research on separating air into it's component gases of which argon is nearly 1%. I see argon is more than twice as heavy as oxygen and nitrogen and will settle to the bottom of a container which brings me to my point: If you set up an air compressor receiver with a distinct low point and rigged a solenoid valve to siphon off the 0.93% or so of your total receiver volume, you'd have mostly argon with a whiff of carbon dioxide for the cost of an extra receiver tank and the metering valve.
About the only problems I can see with the idea is the water that will accumulate at the low spot and there would be some settling time for the argon.
This should be pure enough for welding gas especially if the argon storage is a vertical cylinder to allow further settling and purging of the oxygen/nitrogen from the top.
So the whole concept would run something like this: you use your air compressor with it's tall vertical receiver cylinder as usual, but a microprocessor circuit works out how much air was pumped into the tank to bring it up to pressure (pump run time by displacement). The processor board then purges the water, waits for the argon to settle out, works out 0.9% of the volume pumped in and meters that into the argon storage tank by timing the flow through a capillary.
I'd really like to hear what you guys think about the concept although I realise in the USA you have more options available for gases including owning your own cylinders. Welding gas is expensive here in Australia due to an effective monopoly on supply now that BOC, Linde and Air Liquide are mostly merged and is only available as a rented cylinders. I understand Australian gas suppliers refuse to fill privately owned cylinders ( I could be wrong on this ).
