kb0thn
Stainless
- May 15, 2008
- Winona, MN, USA
Hi Guys,
I am looking for a grease setup that uses a 35 lb pail of grease instead of the 14 oz tubes. I have a Milwaukee cordless grease gun and it works okay. But I can easily go through a couple of tubes of grease in short order and it takes longer to change the tubes than the rest of the grease job. Especially since an air pocket seems to happen every few tubes and that requires 10 minutes and a quarter of a roll of paper towels to get worked out.
This is for the home shop where I am greasing heavy equipment toys. Mostly old stuff with some hard to grease fittings. Getting good pressure is going to be important.
I see $200 China special type setups. Probably want to avoid those.
I see $400 sort of setups. But they seem to be 5,000 PSI. For example:
Legacy L6000 $580.33 Grease Pump, 35 lb./5 gal. Pail, 55:1 | Zoro.com
And then I see a setup that McMaster-Carr sells that has a "booster" on it and can go to 10,000 PSI:
McMaster-Carr
Which appears to be a Mcnaught P3TR. On Amazon as:
https://www.amazon.com/P3TR-Power-L...01CIW2BB8/ref=cm_cr_arp_d_product_top?ie=UTF8
Is this sort of the setup the way to go to grease old stubborn stuff and not to have to change 14 oz cartridge and bleed air as often?
McMaster-Carr
